-   Tips and Tricks (http://www.forestriverforums.com/forums/f88/)
-   -   max generator watts/amps @ 120v (http://www.forestriverforums.com/forums/f88/max-generator-watts-amps-120v-41032.html)
TURBS 05-31-2013 11:54 AM
Maybe this will help with "how big of generator do I need" sticky?
Attachment 31800
Common 120v draws.
A/c 12-16 amps
Converter 1-8 amps
Microwave 8-13 amps
Fridge "electric" 5-8 amps
Water heater "electric" 9-13 amps
Common 12v draws
Furnace 10-12 amps
Fridge on gas 1.5-2 amps
Water pump 4 amps
Co detector 1 amp
wingriders 05-31-2013 02:10 PM
Thanks Turbs
Good to know what each unit draws.
TURBS 05-31-2013 08:14 PM
Originally Posted by wingriders (Post 389536)
Thanks Turbs
Your welcome!
pwb01 06-10-2013 04:35 PM
When you're doing the numbers you must keep this in mind.
The advertised rating in watts for generators are peak watts that it can handle. An electric motor will surge to much a higher draw than rated for a few seconds and that's what the rating is taking into account on generators. They can surge to the higer number for a few seconds.
For example: The Honda EU2000 is rated at 2000 watts or 16 amps. It will only handle 1600 watts for continuous operation so that's the number you want to use. That's about 13 amps. An air conditioner can draw 20 amps continually and surge to 22 or 23 when the compressor starts. Other electric motors to consider; pumps, fans, furnace fans, etc
