-   Cherokee (http://www.forestriverforums.com/forums/f24/)
-   -   2003 Cherokee Weight Sticker?? (http://www.forestriverforums.com/forums/f24/2003-cherokee-weight-sticker-41224.html)
negativez0 06-03-2013 10:45 AM
The sticker in my 2003 Cherokee by Forest River seems to be blank... why is this?
CCC computation GVWR ... 0
Minus UVW Approx ... 0
Minus Fresh Water Weight of 0 Gallons @ 6.3 LB/GAL ... 0
Minus LP-Gas Weight of 0 Gallons @ 4.5 LB/GAL ... 0
= CCC For this Trailer ... Approx 0
The trailer is equipment with water tanks and LP-Gas.
ependydad 06-03-2013 10:51 AM
That's really weird. Is it the only sticker? Is there another hiding somewhere else?
Sounds like a great reason to go hit a CAT scale and find out your real weights. You'll need the GVWR, though to find out your "CCC" (Cargo Carrying Capacity).
bikendan 06-03-2013 11:42 AM
can you post a pic of the sticker? i've posted mine and can use it to compare.
negativez0 06-03-2013 01:22 PM
I've included a copy of the sticker below.
Also, how do identify the model number of the trailer? Perhaps I can cross reference that to some other resources online.
Thanks!
http://i.imgur.com/SEQTEod.jpg
spierce617 06-06-2013 06:23 PM
I have a 2005 Cherokee 28A and my sticker that is filled out is in the cupboard above the sink. It should be yellow. As for the model number I have one one the slide out side of the camper outside up front near where the water heater is. Or you can look by the door as that is where mine is also. I can get some pictures the next time we go to the campground where it is parked.
WEMig 06-06-2013 06:40 PM
Could this be a camper that was purchased by FEMA and re-sold?
