-   Cedar Creek (http://www.forestriverforums.com/forums/f23/)
-   -   Awning, slide, levelng and light remote (http://www.forestriverforums.com/forums/f23/awning-slide-levelng-and-light-remote-44987.html)
Elkrun 07-31-2013 04:43 PM
My Cedar Creek remote for the awning, etc. has stopped working. The battery in the remote seems OK and the lights on the remote light up but nothing happens. I think maybe something might have happen while at the dealership earlier this year. I was going to check to be sure it didn't loose it's memory, but I can't find the relay module per the instructions on the remote. Anyone have any ideas where the relay module might be located on a 2013 CC 36CKTS Touring Edition?
GlenZ 07-31-2013 07:03 PM
Call the service department at your dealership. They should know how to reset it.
Duckogram 07-31-2013 08:13 PM
Open the front garage and pull back the plastic shield on the right side. On the rear bulkhead you will find your relays and fuse box for everything that is independent of the power distribution panel. On the panel there is a button and yellow indicator light.
Follow the instructions on the bulkhead or backside of the remote to reprogram your remote. Hope this helps.
Elkrun 08-01-2013 08:57 AM
Thanks Ducky, I checked there once but I'll do a more through search later today.
Elkrun 08-01-2013 06:37 PM
I found the relay module per Ducky's instructions. The yellow light is not on and when I push the button above the light it does not flash. The relay module may be bad or if it is fused that may be the problem. I assume that the yellow light should be on..........is this correct?
Duckogram 08-01-2013 07:47 PM
Elkrun,
The yellow light does not stay on. The receiver goes into a power saver like mode. In order to program the transmitter to match the receiver you must push and hold the button until the yellow light flashes. Follow these instruction exactly:
Elkrun 08-02-2013 08:04 AM
Thanks Ducky, those are the same instructions that I have. Maybe I didn't hold the button down long enough. I'll try it again and we'll see what happens.
Elkrun 08-02-2013 12:45 PM
Ducky,
I depressed the white button over the yellow led several times and held it depressed for over a minute and the yellow light never started to blink. I think there may be a problem with the relay module.
Duckogram 08-02-2013 06:09 PM
Try using a pencil with an eraser on the end. Sometimes it is hard to get the button to push straight in with a finger. It takes quite a while to get the light to flash so your finger might get tired before you achieve success...
rattleNsmoke 08-02-2013 06:33 PM
Tired fingers are not good...*s.
