-   Coachmen Motorhomes (http://www.forestriverforums.com/forums/f230/)
-   -   Do I have an emergency start switch for my 320BH? (http://www.forestriverforums.com/forums/f230/do-i-have-an-emergency-start-switch-for-my-320bh-49246.html)
cmalberto 10-11-2013 11:02 PM
Does my Leprechaun 320BH have an emergency start switch and if so where would it be hiding. I don't see or can find. I am guessing not but perhaps it may. Does it or does it not - should it or should it not?
Thanks in advance.
2013leprechaun319dsf 10-14-2013 09:49 AM
Not sure what you wish to start in an emergency?
More info?
cmalberto 10-14-2013 10:42 AM
I have heard and even seen on another brand we looked at. I believe the functionality is to give either your Chasis batteries or your Coach Batteries the ability to share power. Not sure which battery is used to start the genny but in theory, it would pull from the other battery if used...and vice versa if the engine battery is too low to start, it will pull from the coach batteries...
Hope that helps clarify what appears to not be present on my rig.
2013leprechaun319dsf 10-14-2013 11:49 AM
Try contacting Ron Ross, Coachmen Class C Service & Warranty Manager at:
rross@forestriverinc.com or
574-825-8602.
Be interested in what you learn.
cmalberto 10-14-2013 05:15 PM
Thanks - I did just now - will advice when I hear back.
cmalberto 10-16-2013 09:11 PM
574-825-8602.
I talked with Ron - he said that my particular model doesn't come with one but is wired for one. Sounds like it isn't that big of deal to have it purchased and installed. About 1hrs worth of labor plus the expense of the switch.
May look at that down the road.
