-   -   3200 BHT Awning Question (http://www.forestriverforums.com/forums/f210/3200-bht-awning-question-55996.html)
Linack1107 03-10-2014 06:10 PM
Does anyone know if it is possible to put a longer awning on the Prime Time Tracer 3200 BHT Touring Edition Executive Series? I know a longer awning rail would have to be put on, I just did not know if there was a reason why the ones on there are so short. It would be nice to not have to walk out into the rain while using the outside kitchen.
I have seen some trailers with the kitchen slide have a much longer awning on it then the one on the 3200 BHT.
Thank in advance for any input or insight you may have on this topic,
Linda
I FOUND THE ANSWER ON A PREVIOUS THREAD!
I don't understand why other trailers with this same kitchen slide out has them and it isn't an option for us.
TURBS 03-10-2014 07:05 PM
Don't you have a big door that flips up?
TURBS
Sabre owners united!
Linack1107 03-10-2014 07:12 PM
Yes, I do however, from the outside kitchen to the awning it is uncovered so you and the food get wet traveling back and forth. It would be a nice little extra convenience item to have instead of the short twelve foot awning that also allows rainwater to come in the screen door because of where it stops on the trailer.
Platokidd 03-10-2014 08:10 PM
Add a second smaller awning over the cooking area if that can fit with the door up.
The fridge slide out I would think would be a problem with one big awning.
I seen a trailer last summer that the guy added a second awning for just that reason, but it was not a tracer.
ependydad 03-11-2014 09:17 AM
I contacted Prime Time about extending the awning on one of the models when we were shopping. They said that the current awning has backers in the wall specifically where the awning mounts. They went back to their engineering department to see about moving the backers but between windows and the slope of the roof- the awning couldn't be moved further back like I wanted. Unfortunately, it nixed the model from our list.
You might want to contact PTM directly. Chris, I think his name is, was a VP and responded almost immediately when I contacted him.
RollingDownTheHighway 03-12-2014 09:53 PM
I have this same camper and with the kitchen slide out, I'm not sure how you could get a longer awning on it. It looks like the top if the kitchen slider would hit the awning
