-   -   FOREST RIVER issued a recall on the CRUSADER model (http://www.forestriverforums.com/forums/f210/forest-river-issued-a-recall-on-the-crusader-model-57346.html)
Sgt. Schultz 04-01-2014 11:21 AM
FYI - Ran across this while looking up another recall --
FOREST RIVER issued a recall on the CRUSADER model - Recalls & alerts - Healthy Canadians Website
Starting date:March 24, 2014
Type of communication:Recall
Subcategory:Travel Trailer
Notification type:Safety
MfrSystem:Structure
Source of recall:Transport Canada
Identification number:2014091
TC ID number:2014091
On certain model fifth-wheel travel trailers, the tires may have inadequate clearance with the trailer slide-out actuator bracket and may be damaged while towing under certain road conditions. This could result in a blow out which could lead to a crash resulting in injury and/or property damage. Correction: To be determined. Owners are advised not to tow their trailers in the interim.
heavynlori 04-01-2014 11:24 AM
Well WTH!?!?! 😱 How can we find out which ones are affected?
Todouble 04-01-2014 11:26 AM
Subscribing! Would like to know more?
ependydad 04-01-2014 12:03 PM
Here is the Transport Canada database search results for Prime Time MFG:
Road Safety Recalls Database
Sgt. Schultz 04-01-2014 12:20 PM
Awesome - a completely different issue identified there -- electric awnings for a whack load of models
heavynlori 04-01-2014 12:22 PM
I saw the awning recall already....
heavynlori 04-01-2014 12:24 PM
I think it was on here actually and gave the details on mfg date period affected
Sgt. Schultz 04-01-2014 01:12 PM
For the Transport Canada Data base
If you run the search using Prime Time it does not show the recall that started the thread - it comes up with the awning one.
If you search ( Road Safety Recalls Database) using Forest River it is the first one on the list
The WildCat one from Jan 30 is scary as well "the Gross Vehicle Weight Rating (GVWR) indicated on the compliance label may exceed the combined load carrying capacity of the trailer axles as well as the trailer hitch pin box"
B and B 04-01-2014 01:39 PM
They also have a recall on 2012 2013 Rockwood/Flagstaff for axle clearance issues. Called my dealer and he is running my SN for my fifth wheel.
B
Todouble 04-01-2014 01:46 PM
4 Attachment(s)
Just went out to look at our crusader. Couch/dinnette slide looks like it's the only one. There's a bracket 1"-1 1/4" away from the top if the tire and it's on an angle so I imagine if your traveling along and hit a pothole and things bounce it will spear the top of your tire.
Attachment 48931Attachment 48932Attachment 48933
