-   -   Torn out tank wiring (http://www.forestriverforums.com/forums/f217/torn-out-tank-wiring-63987.html)
labguru 07-07-2014 11:47 AM
My dog got under the camper and tore apart my wiring for the two waste storage tanks. I still have wires connected to the tanks, but I don't know how to connect them together. It is a 2001 Salem Forest River. The monitor inside only seems to have four wires (blue, red, green and brown) I think, going into it for these tanks. Does anyone have a wire diagram or a picture to help me rewire this back correctly? The wires from the tanks all seem to be 18 or 20 gauge, but I think they are going to wire into a thicker wire.
Dave_Monica 07-07-2014 11:59 AM
I found this pdf that has the info you need...
Dave
labguru 07-07-2014 12:27 PM
So, it looks like all 3 levels in the tank get tied together, then all the whites together. Not sure these colors match mine, but it helps. My monitor is similar to the one on page 163, but not the same. Thanks for the help!
Herk7769 07-08-2014 03:43 PM
5 Attachment(s)
So on the tank:
White - Ground (tie to ground from other tank and run to display.
Yellow - 1/3 light - to red resistor pack
Green - 2/3 light - to red resistor pack
Red - Full - to red resistor pack
Brown Resistor pack single wire to display - Black Tank.
Gray Resistor Pack single wire to display - Gray tank.
