Outside kitchen fridge
In the smaller outside kitchen, I'm assuming when we are plugged into electric, the fridge is automatically on. Is that correct? Can't find any kind of switch for it, but hate the fact of it being on when I don't need it. Thx.
Yes, it runs on electricty only
Sent from my iPhone using Forest River Forums |
If your running on 30 amp service you might want to unplug it or if your not going to use it.
You may have fun unplugging it.
fridge is bolted down. You may be able to shut the breaker off in the distribution panel. Mine has a on/off dial. There's no coldness setting? TURBS "SABRE OWNERS UNITED" |
Next time you are at your dealer ask them to install a electrical outlet for you. You will also be able to use the outlet for optional appliances when camping. Unless you know what you are doing around electricity get help from your dealer or an electrician.
or you could just use a lighted breaker/power bar. That will always tell you if the power is on and gives you lots of options for plugging in more things. I just tuck it neatly beside the fridge. When running off my solar, we turn on first thing in the morning and off before bed. Never had an issue with contents getting warm and the batteries are always full that way.
