-   -   Electrical Help (http://www.forestriverforums.com/forums/f218/electrical-help-66866.html)
Stg1 08-21-2014 11:10 AM
Electrical Help
Hi Everyone.
I'm planning a trip to Dumas, TX and need some help. I'm planning to park at some relatives property, They have electric , but I need to know if the circuit is above 30 amps, do I need to do something else, or will connecting a 30 amp box with a breaker work? Thanks in advance. Please help.
jtstromsburg 08-21-2014 11:28 AM
Biggest thing is to make sure if you are plugging into a 30a plug, it needs to be 120v, NOT 220.
Herk7769 08-21-2014 11:34 AM
Amen brother.
Most home "30 amp outlets" are wired for 220 appliances like welders, compressors, and air conditioners.
Plugging into THAT would be VERY expensive.
DaveSchwartz 08-21-2014 11:43 AM
Of course those other 30 amp receptacles have a different blade configuration. The problems arise when someone thinks they should be wired the same too.
Stg1 08-22-2014 11:58 AM
Thanks for the help. I just need to know if the circuit is say 60 amps do I need to do something other than wire it to a 30 amp rv box that has a 30 amp breaker? Sorry to be so dumb, but I have limited electrical knowledge,
wmtire 08-22-2014 12:04 PM
This sticky we keep in the FAQ section may help you or an electrician wire it correctly.
http://www.forestriverforums.com/for...let-27223.html
Stg1 08-22-2014 01:04 PM
Thanks for the info.
MuddauberE 08-22-2014 01:32 PM
I agree to first test the 30Amp plug with a voltmeter. Make sure it is not putting off voltage in the 220's but only in the 110-125 range. Anything else will blow up all circuitry in the trailer. Being a family members house and they having a 30 amp in the garage, I'm willing to bet that this was probably for a welder or some other item requiring a 220v 30amp plug unless they installed it themselves specifically for a TT. If it is a 50 amp plug, then your plug wont fit. but Why they make a 30amp 120 and a 30amp 220 with the same receptical configuration is beyond me. I have not personally experienced it but I have heard plenty of stories of people who have done this somehow and started a nice fireworks show.:confused:
RedRollingRoadblock 08-22-2014 11:46 PM
Another good site is: RV Electric
And for the 12v stuff: The 12volt Side of Life (Part 1)
TheUO 08-25-2014 06:43 PM
They are not supposed to be the same receptacle...
Travel trailer 30 amp has a specific receptacle labeled TT-30 which has a different configuration that say any of the NEMA 30s (6-30, 10-30 or 14-30). The problem is you can put whatever receptacle you want on when installing and installers are incorrectly using TT-30 receptacles when they should be using a NEMA receptacle for say a dryer/welder/other household item.
This is a TT-30:
http://www.leviton.com/OA_HTML/ibcGe...10251:22372:US
Any of these should be used at home for typical household 30amp stuff that isn't your trailer:
NEMA 14-30:
NEMA 10-30:
NEMA 6-30:
NEMA 15-30:
NEMA 18-30:
