-   -   TV (http://www.forestriverforums.com/forums/f15/tv-68432.html)
coldj 09-15-2014 08:47 PM
TV
My outdoor Jensen TV won't turn on but the power source is on. TV won't turn on remotely or manually. Any thoughts out there!
mcnabbwr 09-15-2014 08:54 PM
Have you plugged anything else in to verify outside power? Maybe tripped GFI.
coldj 09-15-2014 09:05 PM
The lights and refrigerator are working and the red light on the plug in is lit.
mcnabbwr 09-15-2014 09:13 PM
Are they plugged into the same outlet? If not plug a light, fan or other into outlet to verify power. I am assuming its 110v.
VinceU 09-15-2014 09:18 PM
Is it still under warranty? If not you can call and ask tech support if there is a fuse inside the TV cabinet. Otherwise its off to a TV shop, its the power supply, the most failed section of all.
coldj 09-15-2014 09:23 PM
I plugged in my GPS since it has the cigarette lighter type plug in and it worked. TV was working fine the other day. It is still under warranty.
bclemens 09-18-2014 03:03 PM
TV is 12V. Sometimes low batteries will not permit the TV to operate. Might just be the power cord too.
coldj 09-19-2014 11:26 AM
Thanks Mr. Clemens. I applaud and admire your participation, help and information you provide for FR. Will check the cord. I do hear something rattling at the plug in end when I shake it. Sounds like something came loose.
bgilly 09-20-2014 08:48 AM
My center tv (bunk area) stopped working. No blue light on the tv so I figured it had to be power related. Investigated and found the inline fuse was loose. I think it is missing the internal spring in the fuse cartridge - there's no pressure on the fuse from the leads and to make it work I have place the fuse holder in such a way to apply enough pressure to make contact.
Bobby
VinceU 09-20-2014 08:53 AM
Replacement in radio shack for a couple bucks. Good invest if bunks are used.
