-   -   Manual Slide Operation (http://www.forestriverforums.com/forums/f96/manual-slide-operation-72054.html)
Davidceder 11-26-2014 03:54 PM
Any guesses out there if I use the below bit, a flexible drill extension and an 18V battery operated drill if I might be able to open and close my slides in an emergency? Maybe a power drill will do better? I have no access for a crank and prefer not to use a ratchet.
http://www.amazon.com/Electric-Quick...YG84BDE5P4458B
offroad 11-26-2014 04:08 PM
I have one that looks just like that, but I have never tried to use it.
I'd be using it with the same 20V cordless drill I use on my stabilizers.
Davidceder 11-26-2014 04:13 PM
I cannot get straight in with the drill hence the extension. I guess I will buy the bit, not too expensive and the extension I will by at Home Depot so I can return if it doesn't work. I will need the bit and a ratchet if the drill thing doesn't work.
