-   -   2005 Forest River Flagstaff odd electrical problem (http://www.forestriverforums.com/forums/f113/2005-forest-river-flagstaff-odd-electrical-problem-72505.html)
CMoore-trav 12-07-2014 04:26 PM
My 2005 Forest River Flagstaff has been serving me well since I bought it. No major issues at all but on my last RV outing I found that my fridge (both gas and electrical) didn't work and the gas water heater didn't work but the electrical water heater did. I've checked the fuses. All good. Power to the fuse panel checked with a voltmeter and that's good. However, I don't detect power to the fridge board on the outside or to the gas heater connection on the outside. Gas furnace works and gas oven works. I removed the fuse panel to check for possible chewed wires but all the wires are good. With the fuse being good, does anyone know what the gas heater and the fridge share that I should check? The gas furnace comes on right away so I don't think it's the battery so I'm thinking I'm either missing a hidden fuse or I've got a break in a shared power line between the two.
Today I swapped our all the 15&40 Amp fuses for new fuses. No change. I also swapped out the battery for a new battery to eliminate that as a common point but no success in resolving the issue. The common grounds outside are tight, clean, and with no rust at all.
KenHwy61 12-07-2014 04:55 PM
You've got good troubleshooting skills and I think you are on the right track. If you don't have 12V to either the ref. or WH a common fault is likely. I don't know why there would be a another fuse somewhere if the circuit is already fused at the panel. You may want check to see if you have power at the water heater power switch inside the trailer. The only other suggestion I have is to physically follow the 12v power wire from the appliance back to the fuse panel. This may be a pain but sometimes there is no other solution.
CMoore-trav 12-07-2014 05:01 PM
Thanks for the speedy response. The voltmeter reports no power going to the back of the switch either. The switch appears to be in good shape so assuming that it's not the switch, my problem would appear to be between the fuse panel and the switch. Agreed?
KenHwy61 12-07-2014 05:20 PM
I agree. I suspect there is some type of junction point possibly behind a cabinet or who knows where that has come apart. Good luck!
Herk7769 12-07-2014 05:20 PM
When you press the appropriate buttons, do the LEDs light up in the tank/battery monitor?
If not a current limiter between the battery and converter may have opened.
If the lights do not work even with the camper on shore power, you may have a serious problem in the converter (wiring).
CMoore-trav 12-08-2014 12:53 PM
Yeah, lights work and pump works. I've even tried running a known good power lead (verified using a test light) from the back of the fuse panel to the connection on the back of the HW switch to see if that was the issue but no success.
kerrlakelover 12-08-2014 01:20 PM
Just a wild guess...are your appliances in a slide out? If so, could the wire running under slide have a break?
KenHwy61 12-08-2014 01:21 PM
It still sounds like a bad 12v power wire somewhere between the fuse panel and where it splits to feed your appliances. On my old RV my clearance lights quit working and I found after cutting a few inspection holes in the underbelly a mouse had gotten in and chewed right through the wiring including the copper.
limblips 12-08-2014 02:12 PM
I would continue with the jumper wire idea until you find the errant section. You might try going direct from the battery to the WH or Reefer 12v input just to prove it is a bad wire somewhere.
CMoore-trav 12-08-2014 03:05 PM
Slide's not out. I am starting to suspect rodents though. Found a few droppings behind the fuse panel. During the course of my research I found that my Dometic fridge has an outstanding critical recall. I located an authorized RV dealership that is willing to apply the fix this week. As much as it kills me, I think I'll turn this bad wire hunt over to them while I'm still sane.
