-   -   Battery or Inverter issue??? (http://www.forestriverforums.com/forums/f218/battery-or-inverter-issue-72899.html)
Arvicru 12-21-2014 10:23 AM
Hello to all<
Have a question which I hope somebody can shed some light on. Have batteries that are 8 months old and a new Progressive Dynamics IntelliPower 9200 series converter, with the Remote Wizard. So we were driving from Texas to California and started noticing a rotten egg smell typical from overcharged batteries. So I pull over and check by battery compartment and can see one of my batteries is hot and overcharged. I go check my converter and notice that it is in "Boost Mode". I try to toggle the converter to "Normal or Storage Mode" and the it won't let me. So I am wondering if that battery is bad will the converter automatically stay in "Boost Mode" to try to charge is as fast as possible, or do I have something wrong with my converter??? Appreciate all input and hope everybody has a Merry Christmas and Happy New Year.
Brian & Patricia Arvidson
2009 Georgtown
RPAspey 12-21-2014 03:48 PM
A little more info please. What kind of batteries (6v vs 12v) and how many. Next, were you running a generator while on the road thus charging the battery via the converter?
Arvicru 12-21-2014 03:59 PM
(2) 12 volt batteries and not running generator while driving.
rana 12-21-2014 07:01 PM
Brian, the state of your batteries should not affect the charge cycle from your PD. For lack of additional information, and it might seem a little banal, but my first thought would be to check your battery connections. It almost sounds like you have a reverse polarity situation going on.
Barring that.. you might just have a sour lemon. To test that.. I would disconnect the suspected culprit and let your PD run through a full charge cycle on the single battery. Additional follow-up will allow other folks to chime in and see if we can't get this nailed down.
RPAspey 12-21-2014 07:21 PM
A converter only charges the batteries on shore power or if the generator is running. So, if you're getting an overheated battery while driving, you likely have a bad battery. Also, you can't change the converter's mode unless you're on shore power (or generator).
Am I missing something?
fonzie 12-21-2014 07:42 PM
No you're not missing the point. The only way the converter could try to charge the batteries (in this case) if shore power is not hook up or generator is not running, is if it was plugged into an inverter being fed off the batteries creating high circulating currents.
Still Kickin 12-21-2014 08:34 PM
You could use a hyrometer on the battery you suspect being bad to determine if its spent. Or, drive to an auto parts store and have them load test it. At least you will know the battery status.
Arvicru 12-22-2014 12:21 PM
Thank you everybody that chimed in. The battery connections are good and we do not have any reverse polarity. I disconnected the converter for awhile and reconnected it and it is now working fine. I am able to cycle through the charging modes while the unit is charging. I don't know if the converter got "stuck" in a charging mode or what, but it is working fine now. I now need to see if I smoked a battery or not.
Merry Christmas
2009 Georgtown
fonzie 12-22-2014 12:25 PM
How the converter gets it's 120 volt supply while you are driving and generator not running, as per your previous statement?
Evereddie 12-22-2014 01:47 PM
I can't wait to see how this works. Maybe the thing has a perpetual motion machine.
