-   -   Where is drain valve for fresh water tank in 2501 Forester? (http://www.forestriverforums.com/forums/f15/where-is-drain-valve-for-fresh-water-tank-in-2501-forester-77270.html)
suscamper 03-16-2015 12:41 PM
Can't find in manual. Thanks! We just got RV last week and didn't ask in walk through
donanddona 03-16-2015 01:34 PM
I would call the dealer to ensure...
micpib1 03-24-2015 01:12 PM
Passenger side, compartment behind the rear wheels. There is another door in that compartment that contains the water pump, fresh water drain and the water filter. JH
Stinkielee 05-20-2015 11:55 AM
Still can't find fresh water valve.
We have looked pretty much everywhere on our 2015 Freelander 22QB. The storage compartment does not have any kind of door. Do we have to unscrew some of the paneling or flooring in there to find it? We have not looked under the bed yet. That would also mean unscrewing something after removing the mattress.
dieselguy 05-20-2015 12:04 PM
The fresh water drain valve is not really a valve, but generally just a cap on the end of the drain line under the belly of your RV. The cap simply unscrews to drain out the water.
Dino61 05-20-2015 02:43 PM
That is exactly where it is. It is a brass valve.
Still Kickin 05-20-2015 03:00 PM
Unless someone can direct you to it, you might try this. Climb under your RV and locate the fresh water tank. It's connected to the fill tube. Then look around for a drain tube hanging down. Trace the drain tube up into your unit to see where your drain valve might be. If you have one, its going to be between the drain line and the fresh water tank.
That method should get you close.
dieselguy 05-20-2015 03:43 PM
Sorry didn't realize this was a MH and not a trailer.
leftyneil 05-20-2015 04:14 PM
Correct on the location. On my 2015, 2501 Forester it's a quarter turn valve located on the blue water pipe. This will drain the fresh water tank.
HerveVR 05-20-2015 04:19 PM
I dont know where it will be located in the 26th century Forester?
In the old age of the 21st century, the valve might be located behind a round PVC cover on the front wall of the helper side back compartment; right under the fresh water reservoir.
Look around.
