-   -   Coach Air Bag Leaks (http://www.forestriverforums.com/forums/f15/coach-air-bag-leaks-79776.html)
ourflat 04-17-2015 10:05 AM
Coach Air Bag Leaks
My coach air bags always seem to loose pressure when I least expect it, and of course, while traveling down the road. I checked for leaks and could never find a leaking air line or fitting. The air bags are manufactured from Firestone and are a high quality bag so what gives? I decided to install a remote air compressor kit made for air control systems and install it myself. This will allow me to preset the air pressure then the system will monitor for a slow air leak while keeping the pressure at my desired PSI. The kit will also allow me to add air through the same valves if for some reason, my air compressor isn't working so I'm not stuck on the road with no way to add air pressure. The onboard compressor will also allow me to have an air chuck attachment for topping off the air in the tires as needed. Nice feature!
Frank
Joshua Cavitt 04-17-2015 10:36 AM
Going down the road your airbags will slowly leak air. They will have to be filled up every so often. The remote air compressor is a great upgrade! Can you post a picture so we can all see what it looks like and where you ran the lines?
silver 04-17-2015 11:01 AM
My air bag use to leak going down the road also but I finally told her to be quite and it worked:roflblack:
KennyGolub 04-17-2015 11:07 AM
:roflblack::roflblack::roflblack::roflblack::roflb lack::roflblack::roflblack::roflblack::roflblack:
SkipnTerri 04-17-2015 04:28 PM
Frank
Our bags were leaking as well, so we brought it to a local tire shop mechanic. He replaced the valve stem caps with chrome caps containing an o-ring gasket. I added air, tightened them up, and haven't had a problem since doing so two months ago. :thumbsup:
ourflat 04-18-2015 07:26 PM
5 Attachment(s)
Attached are the pictures of my remote compressor install and associated pieces. I deviated from the manufactures directions by installing the main power via a 30 amp relay that I control through the ignition on switch through the little power box beside the coach batteries. By doing this I can keep the power source close to the compressor.
Frank
steverkemp 05-19-2015 12:14 PM
Frank, did you consider adding a small tank? I also want to be able to use the system to inflate the coach tires.
ourflat 05-19-2015 01:23 PM
I did, I just don't think that little compressor is up to the job!
Frank
GL1800Rider 05-19-2015 04:07 PM
Frank, it's hard to tell from the pictures but what model is it?? 72000?? Also, if I may ask, where is a good place to get it. I see a few on Amazon with the 72000 at $388.
ourflat 05-19-2015 05:38 PM
Yes, it is the 72000 kit. $388.00 is a good price off Amazon or EBay.
Frank
