-   -   CB radio (http://www.forestriverforums.com/forums/f232/cb-radio-82023.html)
wayne and sherry 05-14-2015 05:31 AM
CB radio
3 Attachment(s)
Im trying to hook up a CB in JeNNY. I mounted the antenna on the ladder on the Back but my SWR IS LIKE 3.5. Not good. I was hoping the ladder was mounted on a medal frame making a ground. Has anyone been able to install a CB in the FR3 and get a good SWR reading? I'm going to run a founding wire from the antenna mount down to Jenny's frame this weekend, gee I hope that will do the trick.Attachment 76906Attachment 76907Attachment 76908
I ran 50' of coax under JeNNY and come up thru the motor hatch between the seats.
JeNNY (2015 FR3 / 30DS)
2000 Jeep TJ Moab Rock Crawler
2013 Jeep JK
B and B 05-14-2015 05:51 AM
Wayne from the looks of it you are electrically shorting out the antenna mounting it that low, the ladder is a radiator as well. The antenna should be above the ladder as a start. At 50 ft that is a lot of loss at CB Frequencies. What type of coax did you use? Mini RG8 should be a minimum. RG58 would just kill the received signal and transmit power. As you radio is at the from a better antenna location might be beside the Passenger with a short lead.
wayne and sherry 05-14-2015 06:49 AM
Thanks B&B. I have a Wilson trucker on a 10" mass that I will try. Is the ladder a ground? Do you know.?
2013 Jeep JK
wayne and sherry 05-14-2015 09:03 AM
Attachment 76918
Hmmm I wonder if I were to attach a plate to the top of the ladder rails, drill a hole in the center and mount my antenna on a spring if that would help the SWR??
2013 Jeep JK
wayne and sherry 05-14-2015 10:18 AM
Wonder, would aluminum plate work?
2013 Jeep JK
Ron Chamber 05-14-2015 03:26 PM
A better answer would be to get a marine antenna! Also a RG-8 coax would be better for that length. Much less signal loss. Attach the base to any solid surface. An 8 inch ring at the base would help even more if attached to the metal part of the cable.
wayne and sherry 05-14-2015 06:48 PM
I got it figured out. My SWR with this set up is 1.6 on 1 & 40 and 1.5 on 20. Not bad for a 4' tune able tip fire fly antenna. I do have a Wilson 5000 trucker antenna, I'm going to spin that on and see if it gets a lower SWR. Once I got a good ground wire from the antenna bracket to the frame it came in pretty good. At these SWR readings I'm loosing about 6-7% of my CB's power. I'll give a update once l try my Wilson 5000 trucker antenna.
2013 Jeep JK
markangie24 05-14-2015 07:28 PM
I was shocked to read CB. Last time I heard that was Burt Reynolds in Smokey and the Bandit!! Hope you get your problem fixed.
wayne and sherry 05-16-2015 07:12 PM
4 Attachment(s)
I did. And have s good SWR setting now. 1.6 on ch 1 & 40 and a 0 on ch 20. I ran a grounding wire from my antenna mounting bracket down to the inside passengers frame rail just aft of the fuel tank. Great spot there for a good ground. I used 50' of high quality coax that l ran along the passengers frame rail on the outward side of the frame all the way up front. I opened the Engine hatch and brought the coax inside from there.Attachment 77145Attachment 77146
Using sticky velcro I attached the CB mounting bracket to the dash, same with the mic holder. Very clean install and for a RV pretty good SWR match. My antenna is a 4' fiberglass tune able tip fire fly, the radio is a realistic TRC-465 SSB 40ch that's peaked, tuned and unlocked. So far I've talked about 20 miles.Attachment 77147Attachment 77148
2013 Jeep JK
Technorick 05-16-2015 07:25 PM
CB radio
Geeze don't p off sherry and wayne on the road or they will have "Jenny " shoot you with that massive tank mounter on the dash!
I assume One or both of you is ex military?.
2014 FR330 DS
