-   -   slide seal maintenance (http://www.forestriverforums.com/forums/f112/slide-seal-maintenance-88965.html)
gasman94 07-31-2015 06:13 PM
Anyone have any suggestions on how to apply chemicals/preservatives to the top of the slide seals under the slide topper? How do you reach to the inside?
Rich
UmptySquat 07-31-2015 10:24 PM
I just use a rag. If I wipe the outside seals first it gets pretty saturated. I spray some protectant under the outer seal to the inner and wipe it with the rag. I've found it does a great job.
2013 Toyota Tundra 5.7L
2015 Apex 288BHS
dan-nickie 07-31-2015 11:15 PM
For those tough to reach places, I have seen one member post that he wraps some socks around an extension pole.
Paulie Boy 08-01-2015 08:56 AM
Aerospace 303 applied by spraying on and wiping down with a clean sponge. Use the 303 on your tires too! It's like sunscreen for premature sidewall aging and cracking.
Phil57 08-01-2015 11:55 AM
It's not so easy as just spray and wipe when talking about the top seal under the slide out cover. I have done mine from a ladder but I can't reach all the way. I guess the good news is they are protected so the treatment isn't as important.
Paulie Boy 08-01-2015 12:28 PM
Phil, I took a new tennis ball, put a hole in it and screwed onto one of telescoping wash poles. Saturated the tennis ball and coated the gasket. I'm anal, I know!
gasman94 08-01-2015 02:23 PM
Well, I took one of those telescoping wash poles and taped a padded sock to it, saturated it with 303 and did the best I could to cover the seals. I think next time I am going to try to fix a sponge on the end and saturate it before using. Thanks for all of the suggestions.
Rich
81redbug 08-04-2015 12:43 PM
I sprayed the silicone/lubricant on one of those short paint rollers for smooth surfaces and used an extension handle. Worked great.
CA Fisherman 08-04-2015 12:54 PM
Which Aerospace 303 Product
Which Aerospace 303 product is best for slide seals. They make several including 303 Aerospace Cleaner, 303 Aerospace Protectant, 303 Vinyl & Fabric Convertible Top Cleaner and 303 Fabric Guard?
Paulie Boy 08-04-2015 06:28 PM
Aerospace 303 Protectorant is best for the seals, tires and dashboard of the coach. IMO
Paul
