-   Expandable and Hybrid RV Discussions (http://www.forestriverforums.com/forums/f8/)
-   -   Generator/Inverter Help! (http://www.forestriverforums.com/forums/f8/generator-inverter-help-89995.html)
rompinroo 08-13-2015 12:38 PM
Brand new 2016 233S Rockwood Roo...here is the kicker, we went with the 15K btu AC.
What size generator or inverter do I need? Yes, ideally it is likely we run the AC from time to time - summer in "misery" (Missouri) can be brutal!!:trink39:
LandJ 08-13-2015 12:48 PM
Some say a 3000 watt will handle it, some say it won't. I ordered a 13.5K AC unit on our new TT for fear my generator couldn't handle it.
I'm sure you'll hear some of the same, if I didn't already have the gen, I would have gotten the bigger AC. Maybe a couple 2000 in parallel would be the best way to go for you....
Good luck!
jeff64 08-13-2015 12:54 PM
Good luck!
X2
That's the rub with a bigger AC, that extra 10% of cooling capacity is going to need more current/voltage. My Honda 3000i will do the 13.5K Btu but I can tell there isn't a lot of reserve capacity left. Don't want to risk either the AC or genset
SuicideSaints 08-13-2015 12:56 PM
You may get away with a single 3k but there might not be enough cap left to run other things while the AC is on. A couple 2k in parallel may serve you better.
jeff64 08-13-2015 01:00 PM
When in doubt... find the amperage of the AC X voltage (hopefully you can get 120) X power factor (starting surge). It will be at least 1.5 -2 = starting wattage. Even if brief, ie. the Honda has an overload indicator. The shorter the time that is on the better and that in itself should send a red flag up in your head that your pressing your luck.
Understand that all generator mfr. model numbers reflect maximum output not rated or sustained output. That is the true usable output
bikendan 08-13-2015 02:02 PM
you're asking two different things. you have inverters and then you have inverter generators.
there's no way you can run the a/c in a Roo, with an inverter. unless you have a massive battery bank in the back of your truck. and you'll still need a way to recharge the battery bank as that a/c will deplete them after a few hours.
if you go with an INVERTER generator, you'll need at least a 3000w one.
with the 15k a/c, you might want to look at a couple of paralleled Honda or Yamaha 2000w units.
then you only need one if you won't need the a/c.
1st timer 08-13-2015 08:54 PM
I just today picked up a honda eu3000is invertor generator. It's nice! But the box says that the 3000 is not large enough to run a 15K but ac. The pic is of the box the genny came in.
HONDAMAN174 08-13-2015 09:14 PM
Add a hard start capacitor and might be ok.
rompinroo 08-14-2015 07:04 PM
Thanks everyone!! Back to crunching numbers! Most likely parallel's are they way to go. Perhaps moving some place cooler would be cheaper!!
Flybob 08-14-2015 07:12 PM
Advantages of 2 in parallel is that when weather is cool you can get by with only one. Also they are much easier to move around.
