-   -   OK this 2000 watt generator can run a AC (http://www.forestriverforums.com/forums/f46/ok-this-2000-watt-generator-can-run-a-ac-91118.html)
Marines0811 08-27-2015 11:16 AM
https://youtu.be/LV-_7ym8jjA
Looking at 2200 watt from Home Depot. And would be great if it ran my AC.
Pod2Vibe 08-27-2015 11:30 AM
Looks pretty impressive at first but in his other video, it dies at 27 hours.
TURBS 08-27-2015 11:41 AM
2000 running or surge?
It's only around 16.6 amps.
A 2200 watt is roughly 18 amps
13.5k dometic draws 18 amps to start and runs about 12 - 14 amps mine has been clear up to 15 amps in 90 degrees heat and humidity.
Remember you have a converter that runs 24/7 @ 2 - 8 amps.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
gmcnitt 08-27-2015 12:03 PM
Honda..it's worth the difference..........Just my opinion....
bikendan 08-27-2015 01:39 PM
i've always been able to run my 2007 23SS's Dometic 13.5k a/c, with my Honda 2000. pretty much runs the same as this guy's. can this Hyundai be paralled?
and the specs for this show 65db! YIKES, that's high for a 2000w inverter generator. the Honda starts at 53db.
and the Champion 2000w can be purchased for less money than the Hyundai and it can be paralled.
would like to see what this Hyundai does at elevation though.
and did they rate it at 65db, when on Eco or at full throttle?
aceinspp 08-27-2015 02:02 PM
I'm gun shy so I'll stick with my 3600 SIE Boliy. Cost lest than 2 Hondas and has battery start. It's DB is only a couple off of the Honda. I even run my 15000 btu AC. Least I'm not going to worry about burning or blowing something up by using under rated products. Later RJD:trink39:
Marines0811 08-27-2015 02:59 PM
http://www.homedepot.com/OnlineCheck...derItemDisplay
It would be this one. Be mostly for camping in the fall while hunting in State Forests without hook ups. And a couple times in the summer. So would use the AC a little during the day to cool off. No running generators at night in the State Forest
aceinspp 08-27-2015 03:06 PM
Link is useless. Later RJD:trink39:
Marines0811 08-27-2015 03:25 PM
http://m.homedepot.com/p/Ryobi-2-200...200G/205227796
Here it is
TURBS 08-27-2015 03:37 PM
Originally Posted by Marines0811 (Post 966739)
That's only 15 running amps
TURBS
2011 32bhok Sabre
