-   -   Schwintek controller crusader 335 (http://www.forestriverforums.com/forums/f210/schwintek-controller-crusader-335-a-92987.html)
cwc510117 09-20-2015 07:21 PM
Anyone know where to find the controller for the schwintek in the 335bhs? I suspect it is in the small angle under the raised floor by the bed but would like to know before I tear into it. My slide is stopping mid slide and now won't go all the way in so I want to check for error codes.
keepaeyeonit 09-21-2015 02:37 PM
It is located just behind the level control box and mounted to the top of the compartment.
rracer5 09-21-2015 03:42 PM
Mine's in the same place!! And hey......that looks like my clear tote also.:confused: ;)
cwc510117 09-21-2015 07:44 PM
Yep found it thanks...also looks like my plastic bin of toys! Blink code for a short, probably the last thing I wanted to see as I loath electrical issues.
ghiotom 09-21-2015 11:45 PM
Here's the top of one of the motors, after cleaning off the corrosion. The brown wire is supposed to go to one of the sensors, but as you can see there is no connection to the trace. The corrosion had eaten away at the connection. My slide would start to move and then stop, because there was no feedback from the sensor. Anyway, probably something different than your problem, but something to look for.
j free 09-22-2015 01:50 PM
Nine times out of ten it's the motor needing replacement. I had the wiring issue flashing replaced the cable and it ended up being the motor same as above. I hate this system with a passion. At least now I have an extra cable.
