-   -   Break away plug (http://www.forestriverforums.com/forums/f219/break-away-plug-93205.html)
kh3805 09-23-2015 06:43 PM
Break away plug
I accidentally pulled out the black pin that plugs into its power source. Can you tell me where it plugs back into?
davel1971 09-23-2015 06:45 PM
got a picture of "it"
Ford Idaho 09-23-2015 06:52 PM
Little black box like this.
http://www.trojanparts.com.au/images/C93640.jpg
DaveSchwartz 09-23-2015 07:16 PM
If its the box Ford Idaho has shown, just push the pin back in (hard). Its just a piece of plastic that separates two contacts that look like a clothespin inside. Do it sooner than later because you have full energy from the battery going to your brake magnets as long as its out.
davel1971 09-23-2015 07:51 PM
you started a second post with no pic? I'm going to guess this time. Is it the break away for the brakes? TT has a little box on frame tongue, 5th wheels it's on pin box. Hole in front of the box to put pin in. Snaps in pretty tight.
Happy Vibe 09-23-2015 07:52 PM
Break away plug
There is a black box on the side of the frame near the tongue you should be able to push the pin back in. Make sure you do not have the battery hooked with the pin disconnected like this it will damage your magnets if the full 12v is applied for a long time.
wmtire 09-23-2015 07:56 PM
Originally Posted by kh3805 (Post 992209)
Accidentally pulled out the break away black plug- contact...can you tell me where to plug it in?
It will look something similar to this. It should be mounted on the side of you tongue frame. Make sure you push the pin all the way back into the housing. Problem is, if you have not disconnected your battery, you have been energizing the wires/brakes since the pin was pulled. You at least need to go remove the negative terminal from your battery until you get it back in place. You can also melt the switch having it energized for a long time.
https://www.etrailer.com/static/imag...898_2_1000.jpg
kh3805 09-23-2015 10:41 PM
I am new at this 😀
Where is this .... Will I have to unhook from hitch to get to it.
Do I need to disconnect the battery ?
I had no idea its been pulled almost 3 weeks
wmtire 09-23-2015 11:11 PM
Look along the frame rail, usually the driver side.
http://casitaclub.com/forums/uploads...1073947949.jpg
https://www.titanbrakes.com.au/uploa...-08_buster.jpg
kh3805 09-23-2015 11:25 PM
Its a 5th wheel
