-   -   Crusader 370BHQ 2nd A/C Not Cooling (http://www.forestriverforums.com/forums/f113/crusader-370bhq-2nd-a-c-not-cooling-94398.html)
ib4au2 10-12-2015 03:00 PM
We've gone several places since we purchased our unit in July 2015. The problem we're having is the 2nd a/c in the bunkhouse is not cooling properly. We have to leave the door from the living area open and run a fan so cool air will be pulled from the living area. Any help will be greatly appreciated.
BDavis 10-15-2015 05:56 PM
What model AC? There are a lot of posts about defective Brisk Air II models. I have a new 365 saqb that doesn't cool.
ib4au2 10-16-2015 08:25 AM
It's a dometic 15000.There are only two vents in the rear bunk house with no air return.
BDavis 10-16-2015 11:10 AM
They are having an issue with the Brick Air II 15k units. There is a service bulletin floating around. Let me see if I can find it. Regardless it is under warranty in your dealer will take care of it. That is assuming that the unit is less than 2 years old. It has affected the Dometic units manufactured between 2013 and 2015
BDavis 10-18-2015 09:30 AM
Check your ducts for blockage as well. Mine had tape still covering the vent holes.
