-   Blue Ridge (http://www.forestriverforums.com/forums/f200/)
-   -   Cable TV hookup? (http://www.forestriverforums.com/forums/f200/cable-tv-hookup-95560.html)
Busy B 10-30-2015 10:06 PM
Cable TV hookup?
Just bought our 2015 3025rl. There are connections for cable/satellite by both TV's but I can't find where to plug in from the outside. There is one cable in the bulkhead along with an RCA cable but they wouldn't go outside without the hatch open. Any help with this would be greatly appreciated! I'm sure I am just being stupid and missing it...:)
elchilero53 10-30-2015 10:53 PM
My external jacks for Cable/Satellite are next to the shore power plug on the driver's side of the RV. It should be labeled.
mlwilliams808 10-31-2015 12:37 AM
I also have a 2015 3025RL, my cable hook up is on the wall in the water filter / tank drain handle compartment, there is a black cover on the bottom of the compartment that comes out and then the water hose and cable run up through it. Yours may be a different set up than mine.
Busy B 10-31-2015 10:31 PM
I have nothing in either of those spots. The only thing I can find is the 2 cables coiled in the bulkhead but the dealer said those were for an outside tv.
thomas.jackson 11-13-2015 03:52 PM
B, where the water filter is located. My 3025 there are three coax connections. The one for cable, you must put the antenna/cable connection above bedroom TV to cable. TV inputs to cable. For satellite in, the lead goes to back tv, I put sat box on the lead with an hdmi cable to tv. I then run 2nd line to the other coax fitting, which loops to the bedroom, then connect to the tv. On roof, that line runs to the other coax in bedroom. I used a line emitter to check the lines.
thomas.jackson 11-13-2015 07:29 PM
The lines you mentioned in the bulkhead, one is the antenna/cable from the bedroom switch, the other is the video line from the dvd player. The sound is then over the speaker's at the front.
