-   -   ice maker (http://www.forestriverforums.com/forums/f112/ice-maker-99210.html)
Scokat 01-11-2016 06:31 PM
ice maker
next issue, opened the water valve, but ice maker not making ice. moved to bar at ice maker several times and it goes round, but not hearing or finding water inside. any ideas.
tmmar 01-11-2016 07:12 PM
Do you have a Whirlpool residential refrigerator? If so, there is an on/off switch inside the ice maker. You need to remove the bin and the switch is towards the top.
Scokat 01-11-2016 07:28 PM
fridge
its a domitec(sp)
NO3putt 01-11-2016 09:50 PM
Ours does the same thing at times. Couple things to check, is the ice maker pluged in, seperate plug than refridgerator, takes a couple of times to cycle to get water thru line if you had it blown out.
