Old 04-17-2016, 04:24 PM   #1
BDavis's Avatar
Wheels on a 2016 Sandpiper 365 SAQB
Anybody know what the max psi the wheels are rated for? Converting to Goodyear G614 and have read the stock wheels are rated for 100psi - G Rated tires.
2016 Sandpiper 365asqb
2013 Rockwood Windjammer 3006W
2014 F250 6.7 PowerStroke 2wd
BDavis is offline   Reply With Quote
Old 04-17-2016, 07:56 PM   #2
110 psi
jerky is offline   Reply With Quote
Old 04-17-2016, 07:56 PM   #3
denali15's Avatar
Which rims do you have? The rating is printed on the back of the rims.
Here is a pic of mine. These are 110psi; I upgraded my tires to the Sailun's after I had issues with 3 of the 4 tires that came with the unit.
Name:	ImageUploadedByForest River Forums1460940938.239017.jpg
denali15 is offline   Reply With Quote
Old 04-18-2016, 07:29 AM   #4
Always Learning
If you're looking at the Goodyear G614, take a look at the Sailun S637. I'm reading just as good reviews on it and it's cheaper to boot.
Officially a SOB with a 2022 Jayco Precept 36C
Checkout my site for RVing tips, tricks, and info | Was a Fulltime Family for 5 years, now we're part-timing on long trips
Old 04-18-2016, 08:51 AM   #5
lesptr's Avatar
For those that say the rating is on the the back, that may or may not be true. The wheels on my TT do not have a max psi rating stamped on the backside. I had to call Lionshead and speak with an engineer to make sure the could handle the increase from 65 to 80 psi.
2017 Coachman Chaparral 336TSIK
2015 F350 6.7
lesptr is offline   Reply With Quote
Old 04-19-2016, 06:52 PM   #6
BDavis's Avatar
Yes denali215, those look the same. I will look at the Sailun S637 as well. Want piece of mind
Old 04-19-2016, 06:53 PM   #7
BDavis's Avatar
Attachment 105265
Thanks. Think those are it.
Old 04-22-2016, 06:53 PM   #8
I did saliuns as well. Also added shocks, much nicer pulling it now.
Mikele is offline   Reply With Quote
Old 05-08-2016, 04:29 PM   #9
BDavis's Avatar
Went with the Goodyear's. $270 each plus installation. Discount Tire. They were $300 minus $30 each for the 4 month old OEM chinabombs.
Old 05-08-2016, 04:45 PM   #10
I had to replace my rims on my Sanibel so I went with sailun S637 on 17.5 inch rims. My old rims were only good for 80psi so I had to upgrade. I contacted Treadit directly. 4 new rims and tires for $1360.
Prime Time Sanibel Traveler 38QB
2015 Chevy 2500 HD Duramax
crooks07 is offline   Reply With Quote
365, 365 saq, sandpiper, wheel
