04-09-2016, 11:07 PM
#1
Replace Factory Roof Dicor Sealant with Eternabond Tape?
While filling all the voids in the factory application of the Dicor sealant on the roof I got to thinking, is there a better way?
I researched and found out about Eternabond tape sealant. Can I use this to replace all the Dicor on the roof perimeters and vent/ac/antenna penetrations?
Thoughts or opinions welcome!
2021 Ram 1500 Big Horn LvL2 Quad Cab 4x4 5.7L 3.92
Trailer Steering and Integrated Trailer TPMS
GVWR: 7100
GAWRF: 3900 GAWRR: 4100 GCWR: 17,000
Payload Sticker: 1,867 lbs Tow Capacity: 11,767 lbs
Towing a nice 5th wheel near you
04-09-2016, 11:34 PM
#2
Eternalbond tape is fantastic. In my old TT I had a leak in front bedroom. Found the leak to be coming from where the front metal connected the roof membrane. Use the eternal bond tape on the whole seam. Worked great.
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2002 Goldwing 1800GL CSC Trike
2020 Ram 2500 Crew cab 6.5 bed
Ron & Shirley (Empty Nesters)
04-10-2016, 08:01 AM
#3
I removed all vent covers, cleaned the dicor per the instructions from eternabond and then put 4" eternabond tape right over the top of the dicor. It's a lot of work (also not cheap) but I think it's worth it. Water now drains correctly into gutters and doesn't stream down my front cap or the back of the camper over the lights. My 5er was relatively new when I did this so the dicor was still pretty clean and in good condition. I also did the seam on the front and rear. I'll be doing the side seams, overlapping into the top of the gutters this summer. Here are a couple pics.
2015 Rockwood Signature Ultra Lite 8281WS
2015 F250 Crew Cab
04-10-2016, 08:15 AM
#4
2015 F250 Crew Cab
Wow.......nice job. It has a nice clean look.
Mike & Kim Kilday
11' F250 6.7 SD
15' XLR 27HFS EP
04-10-2016, 08:19 AM
#5
Thanks to this post I also was reminded that I have to do the 3 slide seams as well. My knees hurt just thinking about it. ;-)
2015 F250 Crew Cab
04-10-2016, 09:52 AM
#6
Thanks for the responses!
jheacox1, looks great! So the instructions say to just clean and lay over the existing Dicor?
Would completely removing the Dicor and only using the tape be better? Probably alot more work i'd imagine.
Did you clean with Mineral Spirits?
GVWR: 7100
04-10-2016, 11:15 AM
#7
Yes you can apply right over the existing sealant. Clean it then scour it and then clean it again (scouring pad provided leaves residue) before application. They give you a scouring pad and plastic pressure tool but I found my hands to be the best tool for that. They recommend using Eternaclean (which I used) or acetone for an EPDM rubber roof. I was very careful not to get any cleaner on the rubber roof.
Here's their website.
https://www.eternabond.com/
Ray from www.loveyourrv.com is where I got the idea. He has a video on it and his website is a great source of information on all things RV (specifically 5th wheels) related.
2015 F250 Crew Cab
04-10-2016, 11:24 AM
#8
install eternabond over existing dicor... removing Dicor not only a pain but you will probably compromise the roofing material... after cleaning with mineral spirits, I used isopropyl alcohol and scrubbed the area and left it dry an hour before installing eternabond. I did all my seams, front back and gutters and vents and skylights. I feel much better about it now that it is done.
"nothing can now be believed which is seen in a newspaper. Truth itself becomes suspicious by being put into that polluted vehicle."
Thomas Jefferson to John Norvell pg. 2, June 11, 1807
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4 TST TPMS
04-10-2016, 11:36 AM
#9
Hi! You did not install Eternabond around the air conditioning unit...is there a reason? Tks!
Grangalo
2014 Rockwood Windjammer 2809W Diamond package.
04-10-2016, 11:49 AM
#10
How was doing the long gutter seams? I would think it would be a little easier since there is no dicor to clean and scour.
What width of tape did you use?
I was totally pooped out (and lobsterized) after spending 3 days on the roof in the August sun doing everything else. I think I'll shoot for doing the gutters/slides in the early morning and evening this time. ;-)
2015 F250 Crew Cab
04-10-2016, 01:15 PM
#11
No eternabond around air conditioner. There is no dicor covered seam there just a gasket.
2015 F250 Crew Cab
04-10-2016, 01:17 PM
#12
Great Job! Pictures really help.
04-10-2016, 03:31 PM
#13
I bought some 2, 3 and 4 inch tape... I forget what I used where to tell you the truth...
Here is the write up I did last summer/fall
http://www.forestriverforums.com/for...nce-90060.html
2014 Shamrock 183
04-10-2016, 03:43 PM
#14
Thanks for the link to your post. I think I'll go with the 3" tape on the gutter seams.
2015 F250 Crew Cab
04-10-2016, 03:52 PM
#15
The tape on the roof looks nice, but wanted to comment about using it around the gutter seams. I saw a 5th wheel a couple weeks ago that had taped the gutter seams all the way down the front cap and the rear walls. It looked terrible and I could only think that he must have had some major leaks. I doubt that the resale value would be much at all. I would suggest that before you tape the gutter seams maybe someone might be able to post some pics. Maybe there is a nice way to tape seams, but the one I saw I almost .
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Rockford, Michigan
04-10-2016, 04:09 PM
#16
Check out rsdata's post. His looks pretty good.
2015 F250 Crew Cab
04-10-2016, 04:55 PM
#17
I used some eternabond, never again on a new trailer, maybe an old one I was fixing up. When I was ready to trade, the dealer saw the Eternabond and immediately asked what happened and what was it hiding. If you ever do have to replace those vents and such, good luck removing that EB.
Jim & Pam
2017 Ram 3500, Crew Cab Diesel Dually
2014 Hemisphere 327res
04-10-2016, 06:23 PM
#18
Oh yeah. That looks 1000% better than the one I saw.
04-10-2016, 06:52 PM
#19
Canadian Member
I put Eternabond on my previous Roo's roof. I sold it privately and the buyer had no concerns because doing all the roof penetrations like jheacox1 did is obviously a preventative measure, not covering a problem. I suspect that dealer was just looking for an excuse to give you a lower trade-in value.
It's not cheap but it's very effective and long lasting.
2023 Rockwood Signature 8262RBS
2016 Ford F-250 XLT SuperCrew, 6.2L, 4x4, 6'9" bed
2019 Rockwood Signature 8290BS (2019 - 2022)
2011 Rockwood Signature 8293SS (2015 - 2018)
2010 Rockwood Roo 23SS (2012 - 2014)
04-10-2016, 07:57 PM
#20
Excellent job ; with the Eternabond, I to had installed it on a previous tt , should it ever stop snowing here in WNY and warm up it's first on my list for my newer 5er
Thread Tools |
Display Modes |
Linear Mode
» Recent Discussions |
