Old 11-04-2019, 10:49 PM   #1
2016 Dynamax DX3 BH37
3 year transferrable warranty still active! You won't find a cleaner pre owned rig anywhere in the U.S. This is a real head turner anywhere I go.
2016 DynaMax DX3 37BH with 2 slides amp; bunks. Perhaps the most luxurious Super C motor home on the market!
Features exclusive D Max design which maximizes structural integrity amp; stability, Blistein oversized shock absorbers, newly designed aerodynamic fiberglass front amp; rear caps, vacuum Laminated 2" insulated floor, one piece fiberglass roof, Roto Formed ribbed storage compartments, side hinged aluminum compartment doors with paddle latches, integrated Carefree Mirage roof mounted awnings with LED lighting, heavy duty electric triple series 25 entry step, clear vision frameless windows, Aqua Hot Hydronic System, Sani Con emptying system with macerating pump, luxurious porcelain tile flooring, decorative crown molding, MCD day/night shades, solid surface countertops, king size Serta Euro top foam mattress, dual 18,000 BTU A/Cs with heat pumps, 8KW Onan diesel generator, 3,000 watt inverter with low voltage automatic start and 2 upgraded 4D AGM house batteries.
This model is powered by the upgraded 9.0L Cummins 350HP diesel engine with 1,000 lbs. of torque amp; massive 33,000 lb. Freightliner M 2 chassis with 20,000 lb. hitch and 4 point fully automatic hydraulic leveling jacks.
Options include bunk DVD players a Early American Cherry wood package, an exterior LCD TV amp; entertainment center, Jacobs C Brake with low/off/high dash switch, Allison transmission, air brakes with 4 wheel ABS, twin 50 gallon aluminum fuel tanks, electric power windows, remote keyless pad at entry door, 40 inch LCD TV in the living area, Blue Ray home theater system, In Motion satellite, flush mounted LED ceiling lights, convection microwave, residential refrigerator, touch screen premium AM/FM/CD/DVD radio, GPS with color monitor, color back up camera and two color side view cameras.
Will consider transfer with all interior accessories like dishes, cutlery, chairs, rug, etc.
View this ad at Forest River Classifieds - 2016 Dynamax DX3 BH37
DX3AZ is offline   Reply With Quote
