Old 04-19-2012, 07:06 PM   #1
Reese Bed Rail kit
I have a 2011 Silverado 2500. I am needing the bed rails and the under-bed mounting brackets. The 5th wheel is model #30047.
Thanks in advance!
Matt
CenTexPSE is offline
Old 04-22-2012, 07:19 PM   #2
I bought mine from Amazon.com They were Curt custom frame brackets, and Curt bed rails. I think I got both for 196.00 delivered. I installed a B&W Patriot hitch on the Standard Curt bed rails. I installed with the help of another person. It makes it much easier with the extra set of hands. Everything fit perfect. Your Reese hitch will fit into the standard bed rails. Just make sure that the frame brackets are for your truck. I like the custom frame rails in stead of the univercal frame bracket kits. Only had to drill 2 holes in truck frame. The rest of the hole were already in the frame. Nice beefy brackets.
2013 Flaggstaff 8528RKWS 5th Wheel Diamond Pkg.
2005 GMC 2500HD Crew Cab LLY Duramax/Allison
Banks exhaust, AFE intake mouth piece, Volant CIA with ram air scoop, KYB Mono Max shocks, EFI Live by duramax tuner 5 tunes with turbo brake, B&W Patriot 16K Hitch
Paul J S is offline
Old 05-28-2012, 06:36 PM   #3
Great Horned Owl's Avatar
If you buy the Reese custom kit, you won't have to drill any holes in the frame. The brackets will bolt to existing holes.
There are two different custom kits available for your truck. On the old style, the brackets attach on the inside of the truck frame rails. You will need to drop the fuel tank and cut away part of a heat shield over the exhaust pipe.
The new "outboard" custom kit uses longer (48") rails so that the brackets bolt to the outside of the truck frame rails. There is nothing in the way and the installation is much easier. It costs about $40 more and is well worth it. It cuts an hour or two off the installation time and saves a lot of skinned knuckles.
The best prices that I found were at etrailer.com.
Kit Rails Brackets
New Outboard 56001-53 30153 56001
Don't get the told style kit 50066-58
Joel
2011 Silverado 2500HD Duramax, 4x4, crew cab, long bed
Palomino Puma 253-FBS, 27' 5th wheel
1994 19' Class B on Chevy chassis
Great Horned Owl is offline
bed
