Good video but I found it odd that he jacked the wheel from the center of the axle. I always heard that was a nono. Maybe because he had no weight on the frame?
I dont believe Lippert actually packs the bearings initially. the grease they use is semi-viscous...like a liquid grease they can just flow into the cavity. we had a 40% failure rate on the seals the first year of use on 5 rentals.
What makes you think lippert doesn't pack there own axles bearings?
i believe they put grease in. i just dont believe they need to pack the bearing. upon a repack in 60 degree weather, a dollop of the original grease would drop off of your finger. runny grease negates the need for a pack...just add to hub.
