Originally Posted by Vinni
Hello RV Owners. I ordered new 2021 RockWood Ultra Lite.2882S from FR thru the dealer who offered best bottom line. Retailer did walk thru didn’t know much and we didn’t notice much at that time except a dozen screw and some parts in drawers. After using for 3 times out there are issues. 1st time out we notices window valances had screws missing loose and stripped. We were told by reseller that roof was small and factory didn’t like to put solar on small roof. So we contacted Forest River directly and they installed 190watt Solar/inverter option to standard package E with options. (1) Now we have a Go Power solar option with controller and a WFCO inverter that have incompatibility problem so the cable from controller to inverter has been left out to avoid from burning up system. The FR Rep says that is the way that model comes from FR. The consumer is supposed to exit coach go to traffic side of coach turn on and off as needed. What a line of B.S. (2) refrigerator light doesn’t secure to refrigerator wall. Tabs Broken. (3) Screws on stovetop cover had fallen out of hinge (not tightened properly) (4) Sewer Black water valve doesn’t seal properly. Every time cap is removed raw sewage runs out. (5) Water pump switch at water controller doesn’t work. (6) Bedroom closet doors have pilot holes but no catches installed. Doors just slide open and closed when traveling. (7) Front exterior compartment light switch has failed. (8) Protruding screw were LP Connection are to be made to use outside cooking accessories. OUCH! (9) Overhead fan blade bracket Broken. (10) Constitution trash left in floor ventilation vents. (11) Gouges in floor covered up with repair tape to hide from inspection. (12) QC. Wood trim pieces stampeded with 3/8 inch plus gaps exposing raw wood. Please advise. Thank you.
So if I am understanding this correctly as per emboldened in red above, you ordered an RV thru a dealer who is most likely thousands of miles away from you now, hence the reasons why you cannot easily return the RV to this dealer for warranty work (and maybe part of your insistence that it's a manufacturer problem and not a dealer who the manufacture pays for warranty work). If so, we have seen this happen many times before and is why FR has on their websites and brochures to "buy locally" for these reasons, as per this link
https://forestriverinc.com/buy-local.aspx
You will need to find a dealer who is willing to provide warranty work (and can be hard if not the selling dealer) to help you. With pre-approval you can even use a mobile RV tech as many members in your situation have done. Not much anything the members of this community can do for you. This is all going to have to be handled via a dealer or Forest River.
Please be aware of this site guideline:
Customer Disputes: This forum is not intended to be a mechanism for people to solely vent frustrations about services, products, vendors, or sales. Please settle your differences with the seller, provider, manufacturer, or dealer
through other means but not through our community. You may post about problems you have with Forest River products in an effort to learn from others with similar issues, however the use of the forums to repeatedly attack or bash Forest River, Forest River products, or Forest River owners is strictly forbidden.
