Old 01-11-2021, 02:06 PM   #1
Post Palomino Truck Camper and buying a Ford 3500 Singlerear wheel
I was looking at the Palamino slide camper at 3,000 dry, I figure 4,000 wet
I looking at this truck online, I downloaded the ford info with the VIN number but can't figure the payload. I asked the dealer for the information on the sticker. in the meantime, I looked up the info on the Ford VIN decoder but its confusing?
2017 Ford Super Duty F-350 SRW Platinum 4WD Crew Cab 8' Box
VIN: 1FT8W3B62HEC70107
Vehicle Name: Ford Super Duty F-350 SRW
its a Gas truck 8 ft bed with a crew cab
THE SITE: the first row is the diesel the second row is the Gasser
https://www.ford-trucks.com/forums/v...8W3B62HEC70107
File Type: pdf VIN Decoder - Ford Truck Enthusiasts Forums.pdf (259.1 KB, 5 views)
JohnEG is offline   Reply With Quote
Old 01-15-2021, 10:08 AM   #2
MAXIMUM CARGO WEIGHT WITH SLIDE-IN CAMPER Question?
Hi, Ford gives me a number that seems low. Now using the below info would that number be the Dry Weight of Wet weight? The truck Payload number maybe 4,250 lbs but the below number is around 600 lbs less
"MAXIMUM CARGO WEIGHT WITH SLIDE-IN CAMPER
Note: The following chart lists GVWRs and Maximum Cargo Weights (with minimum equipment) by the engine for
each approved pickup model: 6.2L V8 and 6.7L Power Stroke® Turbo Diesel V8"
John G...
3500, 500, camper, ford, truck, wheel
