Is that some sort of vinyl sheet over a substrate? That's what it looks like. If so, you might be able to pull the thin sheet off along with the trim and replace it with something more durable like a cut and painted FRP panel epoxied to the substrate. That would likely stop the powering as well. If you find the powdering is extensive, then replace with some pressure treated plywood. Then reinstall and reseal trim.
Just the 2 of us in a...
"Currently between trailers"
Sold the 246RKS in 2023
