09-12-2022, 04:12 PM
#21
Originally Posted by 2005gts
thank you
i thought about the capacitor, but i have learned the hard way that making too many changes at once can cause confusion about what may/may not be the problem/solution.... as previously noted, SoftStart tech support and I restored the wiring to oem configuration and the compressor starts and runs, so the softstart module is known bad; is the capacitor weak, i don't have a clue (and don't know how it would act if it is..., i only know that the compressor runs now); I/WE will have to wait until a new module is installed to see if there are any other problems.
Bill
Bill thanks for posting this thread. Good helpful info here.
09-12-2022, 05:34 PM
#22
Retired Old Guy
Glad you got it figured out!
09-12-2022, 05:35 PM
#23
thanks to EVERYONE who has contributed to the resolution of this problem
Bill
09-12-2022, 05:42 PM
#24
Bill
09-12-2022, 06:43 PM
#25
Hmmm Interesting photo ..
In not a electrician, so just wondering what the 2nd black capacitor is used for .... is it possibly a HARD start ?
The larger capacitor looks like it is a combined fan and compressor
did you show the capacitor photos to the technician?
Tarpon Springs FL
2022 Salem 24RLXL
09-12-2022, 07:19 PM
#26
i was told that the little black capacitor is the start capacitor, the big silver one is the run capacitor. now you know everything i know..., including that it is apparently a problem with the SoftStart
Bill
the picture above was taken before the restoration of the oem wiring. there is still a red & yellow connected and a black wire connected to the large capacitor that go to the SoftStart. note that in that picture there is a wire missing that goes to some gadget that in turn goes to the big capacitor. the red wire from the black capacitor is the wire i had to make and reinstall (i was told at the time of the original installation that it wasn't need, so i tossed it... also, this picture shows the red/yellow & black wires still connected, they have been disconnected)
09-12-2022, 07:43 PM
#27
What I'm used to seeing (all A/Cs aren't necessarily this way) is that the silver capacitor package with THREE terminals contains both the Start capacitor and the Run capacitor for the compressor, and the black capacitor with TWO terminals is the start/run capacitor for the outside fan.
Larry
09-12-2022, 08:02 PM
#28
could be, dunno; all i know for sure is it goes to/through a little gadget with a funny name you can see in the picture and then on to the silver capacitor..
Bill
09-13-2022, 06:42 AM
#30
looks like a hard start kit was added to the a/c
I would get a hold of the tech and let him know your system has a hard start and will that make a difference to their instructions
I'm betting the new soft start has to be installed on the larger capacitor
https://getrvparts.com/dometic-33118...ard-start-kit/
Tarpon Springs FL
2022 Salem 24RLXL
09-13-2022, 07:29 AM
#31
nope. the tech guy knew all about the PTCR without me telling him because he told me to reconnect the wire, so i "presume" that this was standard with this particular model. when the softstart was originally installed i was told to disconnect the small capacitor's wire from the PTCR. OR, maybe when i was describing everything during the initial install he knew from my description what it was and told me to disconnect it.... (i've slept a few times since then, and none of them were at a Holiday Inn Express)
maybe someone added it at some time or maybe it was original... dunno
the only reason i added the SoftStart to begin with was a discussion on this forum 'way back when' about using smaller generators or that a softstart mechanism was better for the health of the a/c... so, being a guy that likes to try things i ordered one...
at the price, i thought it was a 'forever' thing and now disappointed that it isn't
Bill
09-13-2022, 10:55 AM
#32
Hard Start Soft Start
There are two different items, similarly related but vastly different in actual operation and performance.
The Soft Start system is just that, makes it easy for the power system to start the compressor or motor. It reduces start-up current.
The Hard Start system is for compressors or motors that start under load or for some reason are difficult to start. It really kicks up the current in the starting process.
I suppose one could say these systems are opposite in operation with regard to starting a compressor or motor.
Bob
09-13-2022, 11:45 AM
#33
a refrigerant compressor is always is preloaded at an equilibrium pressure on the hi and lo sides when at rest/before startup, maybe in the 70ish+ pressure and then upon startup it can go as low as the 40s and highs of 200ish. i can understand the surge of amps needed to get it started and get to its hi/lo operating pressures.
i can only guess that a soft start system cause the compressor to do a slow roll turnover/start.
Bill
09-17-2022, 03:05 PM
#34
received the new softstart unit yesterday and installed it today with the help of a Softstartrv tech support person (great people). the newer unit is physically smaller and a bit more installer friendly with fewer cuts and splices.
i am COOLING it now....
Bill
09-19-2022, 06:29 PM
#35
Retired Old Guy
Bill
Cool!!!
09-24-2022, 03:15 PM
#36
not wanting to start another thread, maybe folks will see this here...
now that the a/c is working; is there a GOOD reason to change out the analog thermostat to a digital one?
Bill
09-24-2022, 08:05 PM
#37
New Thermostat
I always have to ask the questions:
(a) If it is working why does one need to change it?
<better looking? <more reliable? <easire to read or set?
(b) What does one expect to achieve or gain by changing it?
<better efficiency? <better performance? <better accuracy
My general rule is; "if it is working, don't try to fix it".
Bob
09-24-2022, 08:11 PM
#38
X2
Bob
The failure rate of a mechanical thermostat is far lower than that of an electronic thermostat.
Larry
09-25-2022, 05:56 AM
#39
i agree: "if it ain't broke, don't fix it".. but sometimes it's hard to tell if something is only 'wounded' or just tired...
i just wondered if a digital thermostat might be an improvement other than having a digital display of the temperature and some buttons instead of slides.
and then a review of the reviews on Amazon of a replacement Dometic analog similar to the one i posted a picture of showed some folks were going to replace their digitals with an analog because the digitals were problematic...
so, thank you
Bill
ps: how come my pictures post sideways?
09-25-2022, 06:16 AM
#40
was your computer/camera level when you uploaded?
when you take a picture especially on a phone... they put orientation information into the pic.
That info is based on what the camera thinks you want...
In the old days if your turn your camera upside down... you get an upside down pic... the auto orientation thinks you want it the other way up.
you can turn off the automatic stuff in your camera settings
Web browsers use that info to make sure the picture is right side up in a web page.
The same picture ... when you click it to view only the picture
It is now no longer inside a web page and the orientation is different.
Tarpon Springs FL
2022 Salem 24RLXL
