I cannot comment on brand.
I bought through eTrailer and they helped me find a unit that was a match to my distribution box and plug compatible.
As far as replacing, the hardest part was getting the new one onto the roof without damage. I used a ladder and slid it up with one person below and above.
The seal is just pressure, four bolts that need to be tightened and compress a gasket.
You will have to gently remove the old one, I used a plastic scraper to release the old gasket. Lots of cleanup prior to installing the new one.
Nothing was that hard, mine was plug compatible with the old so no wiring.
Good luck
https://flickr.com/photos/17321100@N...77720301392493
