Old 03-27-2020, 10:35 AM   #1
access left jack puma toy hauler with generator box
To access left jack remove propane bottle.Grind off spot welds bottom corners, right and left sides. top as far as possible. With a jig saw cut left to right top holes in a parrall line. From left hole grind a line to right side of panel. Pry up plate from bottom , it will break the top loose. Remove panel and you now have access to left jack. You now can service jack. To replace panel screw a piece of angle iron across top of plate. High enough to clear top of tank. Cut 2, 4 inch pieces for bottom of plate 1 right side 1 for left side for bottom section. Use self tapping screw for reattaching iron to plate and trailer frame. Angle cut ends of angle iron near tank for clearance. The gen. box DOES NOT COME OUT OF THE FRONT ACCESS DOOR EVEN IF YOU TAKE OFF THE DOOR.
Thomas ho is offline   Reply With Quote
general topics, generator, jack repair, puma, toy hauler
