Old 02-05-2020, 08:26 AM   #1
JCR
Air Cond easy start
Has anyone installed that new easy start a/c device ($100.00) where you can use a smaller generator?? Appreciate comments and thoughts..
https://www.rv-ac.com/Easy-RV-AC-Starter.html
JCR is offline   Reply With Quote
Old 02-05-2020, 02:08 PM   #2
SeaDog's Avatar
I think if you check the library you will find many articles on the topic included many covering install of same
Retired Navy
2016 Flagstaff 26 FKWS
Old 02-05-2020, 03:04 PM   #3
bikendan's Avatar
Check out this current thread:
https://www.forestriverforums.com/fo...d.php?t=200956
Old 02-05-2020, 03:29 PM   #4
JCR
Thanks ,helps a lot.
Old 02-06-2020, 03:30 PM   #5
I have 2018 27RK Crusader Lite with 30 amp service. I have installed a Coleman-Mach 8 Cub Air Conditioner 9000 btu with heater in the front bedroom. I have also installed 2 EasyStart™ 364 (3-ton) Soft Starter in each A/C unit. Main A/C is a Brisk 15000 btu. Also have installed the Progressive Industries HW30C 30 Amp Hardwired EMS-HW30C RV Surge & Electrical Protector. I had to add in my own wiring to the breaker panel. With this installation it has allowed me to run both A/C units at the same time. I can also run the two A/C units on my Champion 3500 watt generator. Had to fabricate a bypass plug for the generator cause of the Progressive unit.
RUcamping is offline   Reply With Quote
Old 02-06-2020, 03:37 PM   #6
Installed a MicroAir soft start $300 and works great with a Westinghouse 2200 generator- installation was easy Peasy
Steve & Cody the Wonder Dog (he wonders if he is a dog or not)
Forest River - Rockwood
2018 Ultra Lite 2040WS 5th wh
2020 Ram 1500 Eco Diesel Curt Hitch - 392 rear end
sasch is offline   Reply With Quote
Old 03-28-2020, 12:49 PM   #7
JCR
Did you do the 3 times off and on set up procedure? Does your Westinghouse gen. stay up high in RPMS during run time?
Old 03-28-2020, 03:41 PM   #8
I bought mine directly from MicroAir and their instructions called for 5 time on and off and I did do the 5. Yes the Westinghouse gen ran on high RPMS while the AC was running but would drop back to ECO when the AC cycled off. Best wishes!
