Old 10-27-2017, 07:39 AM   #1
Antifreeze - How much?
Hi guys,
First time winterizing my TT. I have a 2017 Shasta Revere and I live in Michigan. I had it winterized by the dealer last year and am doing it myself this year. I got the air adapter to blow out the lines and have successfully done all that (low point drained, holding tanks drained, water heater drained, by-pass valves on, and blowing out the water). I'm to the point where I need to put some antifreeze in the traps and in the holding tanks (I think). Two questions:
1. How much antifreeze do I need in each of the traps?
2. Do I need antifreeze in gray and black holding tanks at all?
Much appreciated!
Paul
peragatz is offline   Reply With Quote
Old 10-27-2017, 07:45 AM   #2
With the lines blown out, are you planning on pumping anti freeze through them? I used a couple gallons pumping it through all my lines, faucets, shower heads, etc.... I take what's left in the jug and dump it into the p traps. I do not put any in my holding tanks, just make sure they're empty.
2019 Silverado 1500
No camper, currently
polishdon is offline   Reply With Quote
Old 10-27-2017, 07:54 AM   #3
Kasual Kamper
I had asked the same question a few weeks back.
http://www.forestriverforums.com/for...ds-144705.html
Search is your friend. Welcome to the forum!
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
JayArras is offline   Reply With Quote
Old 10-27-2017, 08:10 AM   #4
A32Deuce's Avatar
I blow mine out three times after a small wait in between each time, low point and heater by passed and empty. Also filter removed and wiped dry. Run pump to make sure its empty. Then use about a gallon of AF in three traps and into both holding tanks to protect the drain lines/valves to keep the seals wet. No problems in 5 years.
A32Deuce is offline   Reply With Quote
Old 10-27-2017, 08:17 AM   #5
Don't forget to pour a couple inches into the toilet bowl and leave it there over the winter so the seal/gasket doesn't dry out. After blowing out the lines I used 2 gallons in out 5er.
Old 10-27-2017, 08:30 AM   #6
w021095's Avatar
I usually use three to four gallons, depends on the trailer. RV antifreeze is cheaper than fixing a broken water line or valve. Blow out the system through the low point drains, remove the anode​ rod in the water heater, (I put a piece of stainless steel screen in the hole for the anode rod, to keep out the critters)
2018 Rockwood 8328BS
2019 Ford F150 Ecoboost Super Crew
w021095 is offline   Reply With Quote
Old 10-27-2017, 08:43 AM   #7
Originally Posted by peragatz View Post
Hi guys,
Much appreciated!
Paul
If you pump the AF through the lines, as you open each faucet, it will go into the traps and holding tanks anyways.
There isn't really a set amount to use. I used 3 gallons total but I have 4 sinks, 2 toilets, a shower/tub and an outside shower. Even then I still had some leftover that I just distributed among the drains.
Iwritecode is offline   Reply With Quote
Old 10-27-2017, 08:50 AM   #8
Restcure's Avatar
I used a lot more last year to fill the water filter canister (we don't use the filter). This year I heard about a hack to fill up most of the space.
This year I would have used a lot less RV antifreeze if I had remembered to shut off the outdoor shower before turning on the pump.
I also didn't realize that RVAF had lubricating properties and have been using a separate (and expensive) drain lube for years. No more!
2012 Rockwood Ultra-Lite 2701SS, Goodyear Endurance LRD, ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
Restcure is offline   Reply With Quote
Old 10-27-2017, 08:53 AM   #9
w021095's Avatar
Make sure to take the labels (if it's paper) of the water bottle, the antifreeze will dissolve the labels and gum up the pump, had a friend do that. Pumps can get expensive.
Old 10-27-2017, 09:43 AM   #10
I have a rule of having 3 gals on hand when I winterize. Easy to forget a low point drain, outside shower...forgetting to turn off and you dump some antifreeze in the driveway. I drain my black and grey the day before and leave valves open till I pump in antifreeze and that prevents the AF from becoming diluted too much when I pour it down the traps. What I don't use goes back into garage for next year.
TheWolfPaq82 is offline   Reply With Quote
Old 10-27-2017, 10:37 AM   #11
Restcure's Avatar
Thanks for the tip! I'll add that to my dewinterizing steps.
Old 10-27-2017, 01:37 PM   #12
All good points.
Just to add my $0.02....
I completely empty my holding tanks. And leave the valves in the open position over the winter.
I push the sewer cap on put don't turn it to lock it.
If there's any liquid in the holding tank and it freezes my valves or piping don't get damaged and with the cap lose it can always pop off if it does freeze.
And don't forget if you use your water pump to pump AF threw the system. Push the check valve on the city water inlet to allow AF to push out any water trapped in there.
Bobf074 is offline   Reply With Quote
Old 10-27-2017, 03:24 PM   #13
muddyrode's Avatar
just did my 5ver last night right at 4 gallons to do the whole thing outside kitchen, washer/ dryer hook up, both out side showers the inside kitchen and bath
2016 SANDPIPER 35ROK
2013 Silverado Duramax 3500HD DRW LB
Stop worrying about the potholes in the road and enjoy the journey
muddyrode is offline   Reply With Quote
Old 10-27-2017, 04:08 PM   #14
RadRik's Avatar
I empty the tanks on my last trip, open the fresh water tank and low point drain and let them drain as I travel home. When I get home I drain the black/grey tanks into a bucket as some will work its way down into those tanks.
Then I blow out the lines as you did and put antifreeze in the lines with the pump.
After that I blow the antifreeze out into the sinks, shower and toilet.
This puts antifreeze in the traps and a little in the waste tanks. I use a total of just under 2 gallons.
Radi-cool Rik
RadRik is offline   Reply With Quote
Old 10-27-2017, 10:49 PM   #15
We just winterized our Villa Estate 394 FKDS ... used about 2.5 gallons. We didn't do the blowout, just opened all of the faucets, shower, etc., hooked up the pump and started filling. I'm going to go back and add a little to the black water tank just to be safe, though. And yes, we made sure to empty it before we got started. :-)
runmom1 is offline   Reply With Quote
Old 10-28-2017, 05:33 AM   #16
ARLO
I like the water bottle idea. Never thought of that.
rlocicero is offline   Reply With Quote
Old 10-28-2017, 07:26 AM   #17
Homebrew's Avatar
Don't forget your black tank flush and your washer hook up if you have one.
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is offline   Reply With Quote
Old 10-28-2017, 07:51 AM   #18
Crap! After reading this thread I now realize that I forgot my shower lines when I blew out my lines. I tried to pump juice thru my lines last year with no luck. Pump would not pick up antifreeze from jug no matter which way I turned the valve. Guess I will have to drag out the compressor and blow out the shower lines when it stops raining.
USAF Ret. ______________________________________
2015 24 FQSL NITRO TH
2015 2500 Silverado Crew Cab LTZ Duramax 4X4
2012 HD Street Glide
2008 Honda FSC600 Silver wing
hdmtnrider is offline   Reply With Quote
Old 10-28-2017, 07:56 AM   #19
Restcure's Avatar
I thought I'd better do it now... might forget in the spring. w021095, thanks again for the tip. have a drink on me!
Old 10-28-2017, 08:23 AM   #20
Most newer RV's have water less traps and do not require antifreeze.
As far as adding to holding tanks, I usually get enough down the drain when filling the system waiting for the pink stuff to come out. That is if you blow out the water first and drain the tanks completely.
I just did my MH with one gallon of antifreeze.
markb422 is offline   Reply With Quote
antifreeze
