Old 10-30-2019, 05:12 PM   #1
handymanj56's Avatar
Battery
Looked at my rv today, at home... Always pluged in.... Noticed battery had a leak .. red on the concrete took off the battery cover and both caps where off, blown off ? I checked the battery 13.7 bolts... Lights still work on 12 volts... Is battery done or the converter? Click image for larger version
handymanj56 is offline   Reply With Quote
Old 10-30-2019, 05:37 PM   #2
A32Deuce's Avatar
Are you plugged into shore power so that your converter is working?
A32Deuce is offline   Reply With Quote
Old 10-30-2019, 05:39 PM   #3
Yes I have always kept it plugged in when it's home
Old 10-30-2019, 05:50 PM   #4
I just did a test with hydrometer, 2 out of 6 cells where in the fair area while 4 where in the green good area.... Bad cell?
Old 10-30-2019, 06:21 PM   #5
Bluepill's Avatar
Before condemning the battery, try a equalization charge if you have a charger that can output a voltage high enough.
Info here:
https://www.trojanbattery.com/tech-s...y-maintenance/
I bought a "Manual" charger just for this purpose, since I have 6 batteries total between my 2 trailers and cars. It does have to be carefully monitored for voltage, so I do it when I am doing other maintenance and just check every 5 to 10 minutes.
http://www.explosivepowersports.com/...arger-se-1052/
Old 10-30-2019, 06:25 PM   #6
Your battery is likely toast but you may need to look at that converter when you get your new battery or batteries and make sure the converter is going to the correct float voltage. Wouldn't be the first time with the WFCO converters they put in these things.
The caps blew off because the battery was boiling. How were the electrolyte levels when you looked in the cells?
To me, its worthwhile changing these things out even if they seem to be working correctly. A new Progressive Dynamics converter is cheaper than expensive batteries. In your case, looks like you only have one 12V so you got of cheaply.
BTW, the float voltage should be maximum of 13.6V.
babock is offline   Reply With Quote
Old 10-30-2019, 06:46 PM   #7
Water level was just a bit low.... I pulled battery out, hooked up to a charger/conditioner see if that helps... If not I'll probully get a new battery and a converter/ charger .... Will see... Thanks for your help
Old 10-30-2019, 06:49 PM   #8
Trailer Park Supervisor
NJKris's Avatar
Handyman, put your trailer model/year in your signature so we might deduce what converter you have. Babock, seems like just today we were discussing converters, no?
NJKris is offline   Reply With Quote
Old 10-30-2019, 07:02 PM   #9
Yep!
Old 10-30-2019, 07:31 PM   #10
Ok it's there.... Year, model etc
Old 10-30-2019, 08:13 PM   #11
Tapex's Avatar
How far are you from the fires out there on the west coast?
Sorry for off topic handymanj56
2016 Coachmen Apex 250RLS Ultra Light
2019 Ram Big Horn Sport Longhorn
Tapex is offline   Reply With Quote
Old 10-30-2019, 08:37 PM   #12
Hi, fires are all around my county which is orange county... Most of the fires are north of me around 30 to 60 miles away. We do have alot of hills with lots of brush, I'm very surprised we don't have any fires... Knock on wood....
Tom
Old 10-30-2019, 08:39 PM   #13
Tom
They are all near us up where I live. Around 5 miles away at this point but in the eastern part of Ventura county. Kinda normal for us now. Many of my friends are currently evacuated.
Old 10-30-2019, 08:49 PM   #14
Yes seems like every year it's getting worse.. well hope things stay safe for you
Old 10-30-2019, 08:49 PM   #15
Tapex's Avatar
Prayers for everyone affected by the fires. Stay safe out there!
battery
