Look at the bright side, when this first happened to me it was a good excuse to upgrade to two 6 volt golf cart batteries for increased capacity.
Taking a battery very low can cause permanent damage with reduce capacity. If you are not a dry/boondock camper, you should have sufficient power for tongue jack, slides, till you plug in at a campground.
