2015 Sliverback 29RE
Hello, I am trying to assess this situation that I have. When I first bought this trailer I had noticed a stain underneath the bedroom slide out, couldn't ever notice it really being soft though, we've gotten deluged this year and I can tell the very corner of the bottom is soft and that a couple of the carriage bolts going through to the slide anchor have sunk into the OSB board.
It seems like I have that same ole leak everybody seems to get at the bottom trim of the slide out (I cannot believe that RV manufacturers get away with such a stupid problem). I BELIEVE I have now sealed it up as much as can be and so hopefully this won't continue.
Doing some investigating today I have pulled up the carpet to see if I could see the problem inside. Pictures are here:
To show what is happening, the very corner of the floor is where the water has gotten in to the most and so the moisture has made it through the floor and that is where it is starting to rot, its soft on the bottom, not as much inside in the corner but is wet and obviously discolored, starting to rot. This seems to be where the water gets in and then runs down the rest of the seam it looks like. The wood inside where the carriage bolts doesn't look that bad, it obviously seems to start on the outside and just slowly seep inwards.
What I'm trying to figure out is just how urgent is this situation? I have a heater in there right now trying to dry that corner wood out, and hopefully I have it where no more water can get in. Trying to figure out if there is anything else I can do to prolong this, I am full time and in the middle of a pretty large trip and don't have a lengthy stop planned for at least another month, and I don't have the money to pay 3-5k for somebody to repair this, so I'll probably have to do it myself if it comes to that.
Would a wood hardener still be an option at this point? Or am I too far gone for that? What about for at least just the next 6 months?
Thank you!
