Over Inflated?
Where was it said the tires are overinflated?
The trailer weighs 7685 lbs. Divide that by 4 and one has 1921 lbs per tire. The tires are rated as Max. Capacity 2040 lbs, Max PSI 65. Load range D Speed rating M or 81 MPH.
From Carlise tire, "Always make sure that you inflate a trailer tire to the maximum PSI rating as indicated on the tire for best performance and longest life."
At 65 PSI the tires ARE NOT overinflated nor are they overloaded. I'll take the manufacturer's data and specifications over yours.
73
Bob, K4TAX
