Get a hand mirror and a flashlight. It's hard on the neck and back searching fir the pigtail.
So far, in the past I've found most tow package ready Fords to have the plug in pigtail to your seated left of the steering column, like my 2008 Explorer. However, my 1998 F150 based Expedition had a built in the dash slot for a brake controller on the right, and the current Ford F-150 has it's factory trailer break controller also on the right between the steering column and the radio.
Bottom line: IF you have it, it's a crapshoot where to look ;(
UNLESS.....
Try looking for Utube install videos. That is what I did to narrow down my search. You'll need to know the Ford chassis used.
2019 Cherokee Wolf Pup 16BHS flipped axle, 5K springs, 400AH LiFePO4, 3K inverter, 400 watts CIGS solar
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, ITBC, Tow Mirrors, 3.55, SumoSprings, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
