10-16-2007, 07:38 AM
Breakers are HOT, no blown fuses?
for some reason the "general" breaker 20amp, keeps tripping, and the other sets of breakers are getting hot. none of the little fuses are blowing. the converter fan is running occasionally but not a lot.
R we trying to plug in too much stuff? TV, Phone chargers, the fridge and micro is already plugged in.... Laptop charger. and I think the wife has one oil radiant heater on the "low setting"
is this too much? any ideas???
YT
2007 Dodge 2500 QC 4x4 LB CTD
2004 Forest River Salem 39FBRB
2005 Kawasaki 700 4x4 ATV
2002 Kawasaki 300 4x4 ATV
2008 Chinese 110CC kids atv
4 Great Kids......
and a wonderful wife of 12 yrs now.....
Could not ask for more
10-16-2007, 08:45 AM
First I would disconnect all power 12volt and 120volt. Then tighten all screws, or make sure they are tight. Loose screws will generate heat. Make sure your grounds are tight also. Doesn't sound like too much stuff, as most of it is low draw stuff, execpt the radiant heater. Try flipping all the breakers on and off also, doesn't hurt to exercise them once in a while.
Paul B
2001 Excursion PSD
2000 CRV Honda
2006 829GRSS Flagstaff TT
2004 Twin 2000i Hondas'
10-16-2007, 08:56 AM
Are all these items on the "general" 20amp breaker? Heaters will pull large amperage (around 10-12 amps)even on "low setting". High setting will pull 15 amps.
Fridge will pull around 1 amp and the notebook will pull about 1-1.5 amps, phone chargers pull around 1/2 amp.
When the nuker is running it will pull in the 10-15 amp range. My trailer has the microwave on it's own circuit. I cannot run the A/C and the microwave at the same time as it will trip the main 30 amp service breaker.
The wireing in your rig and the breakers are going to be "low quality" probably 14 gauge wire which is barely rated at 20amps and I wouldn't trust it really pulling that load for an extended period. But........ you may also just have a bad breaker that instead of handling the rated 20 amps trips at 15.
FWIW.... my rig has only one 20 amp breaker and that's for the A/C, the rest are 15 amp breakers. And the main service 30 amp.
10-16-2007, 09:35 AM
Cyber Phrenologist
Also, with all this stuff plugged in and running, measure the AC voltage at an unused outlet. The problem may be that you don't have high enought AC voltage coming into the trailer. Eazy fix...move some place where they have enough power!
Radio
10-16-2007, 12:07 PM
The Jolly Mon
Mine has 4-20 amp breakers, and 4 -15 amp breakers.
I agree with the advice posted above. It's good to check the tightness of the screws anyway...many RV's come from the factory with loose electrical screws. (like noted above...don't forget to kill ALL the power first)
In fact....I've seent new trailers catch fire because the screws were loose! Good idea for EVERYONE to check theirs.
Pete (Jolly Mon)
2018 Wildwood Grand Lodge 42 DLTS
-Seasonal Space, Northern MN.
-2017 Sylvan 8522 LZ LES/115 Merc/Sea Legs
10-16-2007, 06:07 PM
I've seen folks (never me) run six 20 foot 30 AMP extension cords to get power and wonder why they are only getting 105V AC at the trailer.
10-17-2007, 01:55 AM
We are directly connected to the "RV" service box 30-amp, on our private property that we are building our home on. Luckly we dont need an extension cord.
As far as the breakers and what they service , the ac unit and micro are on seperate breakers. but the rest of the 110 plugins are evidently on 1 breaker. and all of the plugins are on the pass. side of the RV. (So i assume they are all on the same breaker.)
I will shut everything off in the morning and check the screws in the service panel ect, and see what I find.
Should I change the breaker out for a 25 amp? after i check the size of wire its connected to? or leave well enough alone, as they did "engineer" these things, but as stated earlier, they do it cheap....
Thanks for the tips.....
YT
4 Great Kids......
10-17-2007, 06:12 AM
NO. You never step up a breaker. If anything you step down.
Do you have an empty slot in the box? I know most don’t but if you do you can add another 20 amp breaker and split up your circuits, if they aren’t all fed off of one set of wires.
10-26-2007, 01:40 AM
I went through the electrical box and found a few loose electrical connector screws, fixed them, and could not find anything else that would cause any problems. Since then we watch what is plugged in and we have not had any problems. I also replaced the 20 amp breaker with a new one. Figured better safe than sorry (fire)
Thanks for every ones help and inside info..
154 Full time days and counting.......
YT
4 Great Kids......
10-26-2007, 10:32 AM
I was going to suggest replacing the breakers. I also recommend checking all the outlets. They too can be loose causing more amps to be drawn.
Bill
2006 Hemi Ram Quad Cab 4x4
2005 Cherokee 28A+
10-26-2007, 03:04 PM
Good idea, we all know what kind of quality those RV duplex outlets are...........
10-26-2007, 05:53 PM
Aside from the note that lovely wife is preggy for child #4, which suggests the circuit panel is not the only thing heating up in the Youngtraveller household, am I wrong or is your TT fairly new? If so, I'd have the dealer check out the panel. All the above advice is valid, and maybe you were just overloading the system, but it would be good idea to have the dealer investigate and ensure there is no faulty equipment while warranty is covering it.
- Salem 401-2b; 31" Sony Trinitron and two channels on the antenna.
- Smokin' hot wife... 2 boys, 25 and 10.
83 sweet sweet days camped in 2008 - not easy in my neck of the woods!
10-26-2007, 07:10 PM
Im hoping that FR will cover it under warranty, however with the closest service center a few hundred miles away, and no time right now to take it, we will figure soemthing out....I know they will not do a service call...
and knowing my luck lately since the unit is from texas... the oregon dealer wont touch it......
The #4 child was definatley a surprise....good thing we have a Quad cab truck.....too bad i need a "jump" seat for the jeep now...6 just dont fit in a 5 pass vehicle.....not very well anyways...
I will check the stove for leaks ect tomm morning..
thanks all!!!
YT
4 Great Kids......
