Tile
Hello, sorry I can't help you with sourcing the right tile for your coach. I do remember the Coachman having problems with tile cracking by the slide outs though. If they're not really loose or causing the slide to stick, I would just find a flexible grout in a similar color to make the crack look good as possible. I'm thinking changing out a couple of cracked tiles would be a tough job without damaging others. Hope his helps...
