Definitely the speed control resistor and as said, is mounted in blower housing discharge. Three Fords owned, three resistors replaced. Usually not a big job. A couple screws and a plug.
Giveaway is that it only works on High. This is because HIGH is direct from the control without passing through the resistor which gives the different speeds.
