Old 08-17-2018, 10:42 AM   #1
Camper is MAKING water!
How is this possible? Ive never added water to the fresh tank (2yrs). I accidentally left the drain open. On last trip while fueling up i noticed water draining from the tank.... does anything besides the fresh inlet put water in this tank? This drain has been open evidently since i bought it so i know the tank was empty.
Mikepotts is offline   Reply With Quote
Old 08-17-2018, 10:50 AM   #2
Denver To Yuma In 90 Days
Sounds like the check valve in your water pump has gone bad and city water is back flowing into your fresh water tank.
And the water is probably coming out of the fresh tank overflow outlets.
Much easier (and less expensive) to just install a new check valve in front of the water pump than it is to replace the whole pump.
Just had to do mine a couple of months back...
ID:	183496   Click image for larger version
JohnD10 is offline   Reply With Quote
Old 08-17-2018, 10:53 AM   #3
By the by...
If you need to camp before you get this fixed, just use the fresh water tank and water pump and do not hook up to city water.
Old 08-17-2018, 11:07 AM   #4
Thank you sir! Very good suggestion! We are leaving today for a weekend trip to Gatlinburg. I will diagnose further.
Old 08-17-2018, 11:40 AM   #5
Okay. Got a closer look. I can see where my city water connection ties into the cold main and where the pump connects to the cold main. Im guessing from your pic that the factory check valve is screwed right onto the pump is the one you pictured. This seems like a simple fix now that you pointed itnout. Thanks again.
ID:	183504   Click image for larger version
ID:	183505   Click image for larger version
ID:	183506   Click image for larger version
Old 08-17-2018, 12:32 PM   #6
Happened to me a few months after my warranty ended. I called Forest River and they acknowledged that they had received a lot of calls about the check valve problem and they offered to send me a new water pump. I kept my old pump and replaced the check valve so I now have a spare in case it happens again.
DART is offline   Reply With Quote
Old 08-17-2018, 12:36 PM   #7
Awesome. Thanks for the post. Welcome to the forum!
Old 08-17-2018, 12:38 PM   #8
IndyDave
djhender's Avatar
I had that happen while visiting Bryce Canyon and again another place. It happened after I used the pump the previous day. There is a check valve in the pump to prevet feedback into the tank from the city hookup. Mine would get stuck once in a while. I cycled it a couple times and then watched the tank indicator lights to see if it was filling again. Cycling the pump seemed to clear the problem both times.
IndyDave
2013 Palomino Columbus RS320
2012 Dodge RAM 2500 Diesel
djhender is offline   Reply With Quote
Old 08-17-2018, 12:43 PM   #9
onetonford's Avatar
I would put the check on the outlet side of the pump that is the side without the filter screen. would keep the pump from being pressurized and possibly damaged if you get high water pressure from Camp ground.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is online now   Reply With Quote
Old 08-17-2018, 01:00 PM   #10
Don't understand how that would or could happen.
I don't think it really matters what side of the pump it is on, but I figured that it would be better to have the back flow preventer (ie.- check valve) in front of the pump.
Makes more sense this way to me...
Old 08-17-2018, 01:03 PM   #11
Okay. Got a closer look. I can see where my city water connection ties into the cold main and where the pump connects to the cold main. I'm guessing from your pic that the factory check valve is screwed right onto the pump is the one you pictured. This seems like a simple fix now that you pointed out. Thanks again.
There is no factory check valve...it is built-in to the water pump.
I replaced not only the check valve, but that screen filter thing as well.
Cleaned out the old screen (was full of plastic shards from the factory) and kept it as a spare.
Put the check valve right at the pump and the screen inline in front of the check valve.
Old 08-17-2018, 01:04 PM   #12
I had the same thing happen with my new non FR trailer.I learned The check valve in some pumps can't be replaced or serviced. A new pump solved the problem. This conversation reminded me that I haven't received reimbursement yet for the new pump. I gotta call my dealer.
DrLewie
Flemington, NJ
Former: 2007 Cardinal 30W LE
Now:2018 Arctic Fox 27-5L
2008 Ford F-250 Long Bed Diesel
Total of 30 Months on the Road Since 2008
DrLewie is offline   Reply With Quote
Old 08-17-2018, 01:08 PM   #13
Thanks. This too is good to know.
Old 08-17-2018, 01:11 PM   #14
A new water pump...$80 - $200...depending on whether you want to go basic or upgrade to better pump, plus a couple of hours to swap out.
Check valve...under $15 dollars and maybe 10 minutes of your time...PRICELESS!
Old 08-17-2018, 01:14 PM   #15
If you have not used your water tank in 2 years you may think about sterilizing your tank before use
wcrafter is offline   Reply With Quote
Old 08-17-2018, 01:17 PM   #16
onetonford's Avatar
I personally wouldn't I've had the rubber diaphragm on the pressure switch leak also that also goes for the rest of the pump. If you use just city water it may leak some time before you notice it. Also one less restriction on the suction side of the pump is better as the pump pushes better than it sucks.
2011 25 RL Wildcat
Old 08-17-2018, 01:35 PM   #17
I've found that since I put the check valve in front of the water pump I get less air bubbles in the line when the fresh water tank gets low and the pump is sucking off of the bottom.
Old 08-17-2018, 01:39 PM   #18
On my pump the check valve is an internal part that installs within the water pump housing so it only goes in one way (as far as I can tell)
Old 08-17-2018, 01:44 PM   #19
Flybob's Avatar
Before you replace parts, try this.
Shut off city water
Open faucet and run until no water comes out
close faucet.
Assuming there is some water in the FW tank turn on the pump.
Let water run for about a minute
Shut off faucet.
Once pump stops running, turn it off.
Reconnect city water,
This will reset the back flow valve in the water pump.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-17-2018, 01:48 PM   #20
That is what the check valve does...keeps the water flowing in the direction that it is supposed to run.
Not backward...where it will flow through the pump and back in to the fresh water tank.
Most RV water pumps today DO have the check valve inside of the pump, which is why many of us choose to put an outside-of-the-pump check valve in so we don't have to keep changing out water pumps.
camper, water
