Old 05-02-2020, 08:55 AM   #1
Center lights not working
I have a 2015 surveyor by forest river. It’s a 34BH. I have already had to exchange the converter/inverter. I am getting 12+V to my battery and I’m getting 12+volts out of my battery. Everything running off of 12 V is working except the things that are controlled by the panel below. Everything running 120 is also working. However, I cannot get the awning lights, indoor center console lights and the outside light to work. I have checked all fuses and they are fine. Is there a fuse somewhere in line that I’m missing?
woodwin7 is offline   Reply With Quote
Old 05-02-2020, 10:00 AM   #2
You don't say so I am assuming, and we know how that works, that the Slide and Awning on that panel go in and out, it is just the lights that don't come on, right?
Do the switches pass power? If so there could be a break in the wires between the switch and lights. Have you tried a bypass wire to make sure the lights work? After fuses, that would be my next step, are they burned out.
Good luck.
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
Dwilcox is offline   Reply With Quote
Old 05-02-2020, 11:05 AM   #3
Right. Slide out and awning work without any issues. Good thought and thanks! I will check that next.
light
