Old 11-20-2020, 09:52 AM   #21
Originally Posted by Saab1001 View Post
I haven’t been able to locate one. Last night I found these connections. The yellow wire coming out of the bottom one is the wire to the microwave. There is power to some and not others. Not versed in electrical components and never seen these. Photo was turned again. Left is top. This was located behind the television cabinet setup. Took it apart last night. This plug is dead also.
Those blocks are Self Contained Power Connectors. The parts with the clear covers are for Romex cable and the parts with the blue covers are for round cables. They use them where they want to connect those cables and not use a junction box.
Does the yellow cable come from the power center or does the SO (black) cable?
Gotta go campin!
Old 11-20-2020, 10:08 AM   #22
D W
D W's Avatar
When I test and reset my GFCI the remainder of my plugs go out. I don’t have a fireplace. Guess that is why that one didn’t come to mind. Any other ideas?
The "FP" could simply mean that it's "prewired" for a fireplace.
2016 Salem 27RKSS
D W is offline   Reply With Quote
Old 11-20-2020, 03:13 PM   #23
Thanks for all the help.
Problem solved. The top half of the circuit breakers did not work. Was told it was the plug and cord. one side wasn’t working. Had the park send an electrician and that was the case. 1/2 of the 50 amp breaker was bad. All is good and working. Now I have to put everything back together. Thank you for all of your help in trying to troubleshoot.
Saab1001 is offline   Reply With Quote
Old 11-20-2020, 03:30 PM   #24
Thanks for coming back and letting us know. Many do not and we never know the resolution.
I'm not sure if someone asked in an early post if you had a multimeter and knew how to use it. 5 minutes with a meter checking basic electrical circuits would have found the problem and got you back in operation in a jiffy.
I know electrical is not for everyone but my advice is... if anyone has any skills at all, a multimeter is a tool everyone should have as part of their arsenal. They are really easy to learn to use and can save hours of looking for a needle in a haystack.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 11-21-2020, 09:37 AM   #25
wmtire's Avatar
Glad you got it back going but I still think your panels circuit breakers are mislabeled.
2011 Flagstaff 831 RLBSS
Old 11-21-2020, 10:50 AM   #26
I agree 100%.
Old 11-21-2020, 11:35 AM   #27
rracer5's Avatar
This is where the fireplace would be installed if equipped. The 120v outlet is a dedicated outlet just for the fireplace (notice that the bottom half of the receptacle is blank, can only plug 1 thing in) which makes the breaker labeled FP dedicated to just that outlet.
It's the same type of setup on my Sanibel (big sister to the Crusader).
2014 Prime Time Sanibel 3250
rracer5 is offline   Reply With Quote
Old 11-21-2020, 05:12 PM   #28
Just as confused as you
Scrapper's Avatar
Does anyone notice the top breaker looks like a GFI breaker? I agree with wmtire, your label doesn't match the breakers in the panel.
Richard & Jill
breaker
