Originally Posted by Saab1001
Problem solved. The top half of the circuit breakers did not work. Was told it was the plug and cord. one side wasn’t working. Had the park send an electrician and that was the case. 1/2 of the 50 amp breaker was bad. All is good and working. Now I have to put everything back together. Thank you for all of your help in trying to troubleshoot.
Thanks for coming back and letting us know. Many do not and we never know the resolution.
I'm not sure if someone asked in an early post if you had a multimeter and knew how to use it. 5 minutes with a meter checking basic electrical circuits would have found the problem and got you back in operation in a jiffy.
I know electrical is not for everyone but my advice is... if anyone has any skills at all, a multimeter is a tool everyone should have as part of their arsenal. They are really easy to learn to use and can save hours of looking for a needle in a haystack.
