Campers,
I am a new new owner of a Coachmen Clipper 128ls pop up. Yesterday I was setting it up to clean it out before our first camping trip next weekend. When raising the box on the pop up I felt some slight tension. I stopped trying to raise the box after feeling this tension and walking around to make sure I had remembered to unclip all four latches from the box. After making sure nothing was obstructing the box I proceeded to raise the roof and then felt a pop. This frankly scared the poop out of me. This time I grabbed my wife and we both gave it a 360 inspection. We couldn't find anything that looked out of the ordinary around the camper. We then continued to set it up like normal and then found the problem.
Apparently our Coachmen Clipper model has support cables in addition to the ones connected to the winch system for raising/lowering the roof. There are two white cables per bunk which help hold the beds level without using external bars to hold the beds. There are also four additional black cables on the sides of the camper. It was one of these black cables that was the culprit. One of the black cables on the passenger side (or side that the pop up camper door is on) got caught on the bar end of the bed and bent it when raising the camper also fraying the cable and making it loose along with it's mate.
Here is a picture of the cable showing the fray
This one shows the lack of tension
And finally this picture shows the damaged bunk end
Now this problem is 100% my fault, I don't want to claim a warranty or something. I did this myself and accept the problem. The bunk still slides in and out fine so I don't want to mess with trying to replace the rail. Want I really want to know is will those two black cables on the side mess anything up by not having tension in them? If so is there a place I can order them from and just replace them?
